Which one!
Old Jul 23, 2009 | 07:21 PM
koz's Avatar
koz
Default Which one!
Which one
JVC KW-AVX810 $359.95
JVC KW-AVX720 $356.95
Old Jul 23, 2009 | 08:12 PM
Spike100's Avatar
Spike100
Both are good. You should select the one that has the features you want.
--Spike
Old Jul 24, 2009 | 04:33 AM
StreetOC192's Avatar
StreetOC192
The pro's of the AVX810 over the other unit:
More preamp outputs (5ch instead of only 3ch)
higher voltage preamp outputs (5v instead of 2.5v)
iPod control built in
SD card slot (no usb slot, if this appeals to you)
AAC support (in case you listen to lossless Apple format)
European tuning (if you take your car over the pond)
Detachable face
The pro's of the AVX720 over the other unit:
USB slot (no SD card slot, if this appeals to you)
More sensitive FM tuner (9.3dbf instead of 11.3dbf)
Higher s/n on dvd player (98db instead of 95db)
Other than this list, they are pretty much the same. Pick the one that has the most features you desire. They also look different, so take into account the aesthetics of the unit as well.
Old Jul 24, 2009 | 04:59 AM
koz's Avatar
koz
thanks guy
this will give me more guidence
which would be a good/easy bluetooth, phone add on to either one of these units
Old Jul 24, 2009 | 06:07 AM
ProperID's Avatar
ProperID
Detachable face
according to Cruthfield, they both have USB and SD inputs....not sure if they got that right or not.
I agree with you that they are so similiar, that if the pre-outs don't influence the purchase, then I would go with whichever I think looks the best.
