Amp install kits
Old Aug 3, 2009 | 02:33 PM
ALO8's Avatar
ALO8
Default Knukonceptz Amp install kits
I was going to install some subwoofers and an amp but needed some advice on which kit I would need. Items to be installed:
4 channel amp (4x150watts) bridged into two channels (2x300watts 4 ohms).
2 300 watt dvc 2 ohm subs
i have no clue which kit would work, some look like they are the same. I prefer gold plated rca cables, thanks
http://www.knukonceptz.com/productMa...lation%20Kits#
Old Aug 4, 2009 | 05:46 AM
ProperID's Avatar
ProperID
If you don't plan on adding any more amps in the future, you should just pick whichever 4 gauge kit comes with the RCA wires you want. (avoid the 4 channel kits on that page you linked...you won't need that for just a sub amp install)
If you think you might add an amp in the future, it would be a good idea to run a 0 gauge kit.
