subs vs. hp
Old Aug 4, 2009 | 05:13 PM
nofearsuzki199's Avatar
nofearsuzki199
Question subs vs. hp
i have a 03 z which i put a 9500 10" in the trunk and 1000.1 kicker mono amp which slams i might add.... but it has cut down my take off and horsepower feel quiet a bit... is there anything i can take off? spare tire etc? that would help out? or anything i could add thats not too costly to help revive my baby?
Old Aug 4, 2009 | 06:10 PM
SatchScream's Avatar
SatchScream
Just take the subs out when you run it....?
Old Aug 4, 2009 | 07:10 PM
Tell you want. I will put as much effort into this as you have. Agree?
Old Aug 5, 2009 | 04:15 AM
StreetOC192's Avatar
StreetOC192
Do you track your car? If so take the advice of SatchScream. There are Molex connectors you can use to make the power and speaker cables plug and play.
If not, there are several ways to approach this issue.....
1) Live with the very minimal loss you 'think' you feel in your butt dyno. (What are you adding? 50 lbs max?)
2) Remove the sub/amp combo and regain your supposed hp loss, but lose your 'slammin' bass.
3) Remove some weight from elsewhere in your Z (a simple search will yield TONS of threads on shaving weight.
4) Sell your current setup and purchase a lighter setup.
Tochigi_236
Sep 27, 2015 03:40 PM
_koubie_
Sep 20, 2015 06:34 PM
