Multichannel amp or Mono for sub?
Old Sep 23, 2009 | 01:10 PM
dkwang's Avatar
dkwang
Default Multichannel amp or Mono for sub?
I have a setup planned for a double DIN head unit, with component speakers as well as a 10" sub. If I have this right, here are my options:
1. Buy a mono amp dedicated to the 10" sub, run the 2 front components through the HU's built-in amp.
2. Buy a multichannel amp that runs the component speakers and the subwoofer through it.
What are the pros/cons to either? I appreciate the help in advance.
Old Sep 23, 2009 | 01:37 PM
dkwang's Avatar
dkwang
Spoke too soon.. did a search and found my answers. *sheepish*
I think i'm going to let my aftermarket power my components and use a mono for the sub.
Old Sep 24, 2009 | 04:13 AM
StreetOC192's Avatar
StreetOC192
Option #2 would be an overall better option.
The built-in amp sections of ALL headunits are very poor. I don't know of a single headunit that will output more than about 15 wrms in the real world, regardless of their inflated ratings (and that's being generous). They also use inferior componentry that can color or otherwise distort the sound.
Also, if you are running a sub with a 600 wrms amp and the components with a 15wrms headunit, the components will have a hard time keeping up with the sub. You could turn the gains down on the sub amp, but then you wasted money on an amp that you aren't using to it's fullest potential.
It would be like driving your Z no more than 10mph just so your g/f can keep up with you on her Schwinn.
Old Sep 24, 2009 | 08:52 AM
dkwang's Avatar
dkwang
Thanks Street OC. I heard it would be the other way around, however, if I choose to use a multichannel amp. Most of the realistic ones I was looking at (read: ~500 bucks) would only put out a ~200 watt RMS for the subwoofer MAX. Given my budget of only allowing myself to purchase one amp, I'd rather have my subwoofer be the "Z" than having it be the "Schwinn".
Good advice nonetheless, appreciate it.
Old Sep 24, 2009 | 09:04 AM
cbr900son's Avatar
cbr900son
http://www.edesignaudio.com/index.php?cPath=1_22
Old Sep 24, 2009 | 09:37 AM
StreetOC192
Are you saying you have ~$500 budgeted for amp(s)? if so, that is plenty to get 1 or 2 amps that will power the fronts as well as the sub.
Old Sep 27, 2009 | 06:15 AM
Maddawg's Avatar
Maddawg
try the Alpine PDX-5...1000w 4chnl+300w sub.
m_0g
Jun 3, 2021 10:05 AM
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
cashmoney03
Sep 27, 2015 05:24 PM
Shane86
Sep 17, 2015 05:33 PM
