Iphone video problems on Pioneer 4100DVD
Old Nov 21, 2009 | 10:24 AM
Staisman's Avatar
Staisman
Default Iphone video problems on Pioneer 4100DVD
I have Pioneer 4100DVD in my car and connected Iphone through the Pioneer Iphone cable. When I try to watch video files from Iphone; Pioneer shows black screen only sound u can hear. Anybody had the same problem ?
Old Nov 26, 2009 | 06:45 PM
dragonfire6's Avatar
dragonfire6
Default ...
Are you actually using the Pioneer cable or are you using the charge/sync cable that came with the iPhone?
Old Nov 27, 2009 | 11:45 AM
Beast101's Avatar
Beast101
Default Yeah I have the same problem
I've used an authentic pioneer cable, a different Ipod, and my bypass is done correctly. The only thing I haven't tried was use a "purchased" video from Itunes. But that really shouldn't make a difference because it plays on the ipod.
Old Feb 4, 2010 | 11:26 AM
fall0ut's Avatar
fall0ut
sorry for reviving such an old topic.
i recently installed the same HU with the Pioneer Car CDIU200V installed. i also did the relay bypass so i would not have to flip a switch to watch movies while the vehicle is in motion. please no lectures, im not gonna actually watch movies and drive. i honestly did it for the gucciness.
i had the same issue as the op. i found the fix on another site and thought i would revive this topic for anyone else that has the issue and searches to find this topic as i did.
::: SOLUTION :::
assuming all wires are connected properly (a good way to test is put in a normal dvd movie and see if you can watch it with video and sound.) turn the unit off. then open the av menu and select initial menu and set AUX 1 to IPOD. then select the ipod source and set the background to nonE or off.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
