Passport 8500 Install
Old Aug 29, 2005 | 02:14 PM
  #141
jikman01's Avatar
jikman01
I hear you on that one. I went through at least 2 different phone cords before I found one that I could strip properly. The first couple were like you described. I have a very high quality stripper (wire stripper that is) and still had issues. Even with the one that worked out for me it was not that easy becaue the guage of the wire is so small that if you don't get it just right you'll ruin it.
Suggestion I have is to to out to perhaps a Radio Shack or if you work in a place that has a computer network support or telecom group, take your phone cable to them and ask them to strip it for you. There is a special tool that they use for stripping phone wires which works MUCH BETTER than trying to strip it with a regular wire stripper.
Good luck.
Old Aug 31, 2005 | 03:13 PM
  #142
Fletch69z's Avatar
Fletch69z
Good luck.
Thanks man! I'm going to try using my teeth and see what happens. I've heard from a couple people that that's the best way to do it. I just always have 1 little tiny gauge wire left and I actually got both sides stripped down to one little wire and tried it and I'm getting no power even when I switch them. So, it's not that I have them hooked up backwards. Does it matter if the phone cord has 2 pieces of wire in it or 4? I tried both and couldn't get either to work. It seems like as long as they are the middle pieces that should be all that matters and both types of wire have them in the middle. Who knows, this sucks and I thought this would be easy!
Old Aug 31, 2005 | 04:07 PM
  #143
jikman01's Avatar
jikman01
Believe me, I went through exactly what you're going through...just read the first few pages of this thread where I start posting and you'll see what I'm talking about. It doesn't matter if your phone cord has 2 or 4 wires. Make sure you check out the wiring diagram in the 2nd page of this thread. I think it's backwards though. The wires need to be making good contact also make sure your ignition is all the way to the setting before the car starts as it doesn't turn on on the first setting.
Old Sep 3, 2005 | 06:02 PM
  #144
thrill350z's Avatar
thrill350z
here's my install, the wires on the phone cord were messed up, they were backwards
Old Sep 10, 2005 | 01:26 PM
  #145
sd_diver's Avatar
sd_diver
... Where are you guys finding the hard wire kits for 10 bucks? I have only found them for $30 plus shipping. Any help would be appreciated! Thanks!
Ordered mine thru Amazon - should be here on 9/12
http://www.amazon.com/exec/obidos/tg...=UTF8&v=glance
sd_diver (sneaking over from the G35driver site!)
Old Sep 15, 2005 | 03:14 PM
  #146
kempilot's Avatar
kempilot
Default Easy install
Twenty minutes to do . Used a box cutter and just lightly shaved the insulation on the phone cable till the first sign of raw wire . then just used my fingers to remove the rest .
Thanks Mike!
Attached Thumbnails Passport 8500 Install-imgp0109.jpg   Passport 8500 Install-imgp0107.jpg
Old Nov 2, 2005 | 10:52 AM
  #147
tomcatm's Avatar
tomcatm
Will this work with the g35/350z mirrors? It says that it works on the infiniti fx35....
http://mysite.verizon.net/ccm.gerber/quickconnect.htm
Old Dec 29, 2005 | 12:59 PM
  #148
Fletch69z's Avatar
Fletch69z
Never mind about the wiring kit. I just went to Radio Shack and bought a phone wire plug in with the wires already stripped and with gold plated connectors on the end for about $3, . I love it.
Old Jan 4, 2006 | 05:24 PM
  #149
TeamSpeed's Avatar
TeamSpeed
I have folks over on the G35driver forum using my product successfully using their mirror for power. I believe the 350Z shares the same mirror. Even if you don't want to order one of my cords, please feel free to use my installation guide to give you an idea on how to DIY and the wire colors you can use to power your Escort/Valentine 1 from your mirror, provided you have the upgraded mirror that has switched power. This all started from my fellow Corvette forum members over a year ago and has since been installed on many other vehicles. Alot easier (about 1 minute installation) versus the other activities of running power cords and tying into the fuse box or other sources of switched power!
http://www.invisicord.com/install.html
Old Jan 4, 2006 | 07:48 PM
  #150
md1400cs's Avatar
md1400cs
Originally Posted by ChrisMCagle
Yup! You are correct. You can jam (or shift) the hell out of Laser all day long, but don't try it with radar or you'll get a quick trip to the pokey!
Are you SURE?
I just looked up the CADMV 28150.0 (a) claims that it is absolutely against the law in CA to have a jammer equipment attached to a vehicle.
I want one with my Escort but...
MJD
Old Jan 12, 2006 | 06:44 AM
  #151
BobbyRitz's Avatar
BobbyRitz
Mike,
Are your mounts for the 8500 X50 still available?
I'll PM you as well.
Thx.
Old Jan 12, 2006 | 03:54 PM
  #152
MIKE3348's Avatar
MIKE3348
Originally Posted by BobbyRitz
Mike,
Thx.
I still make the X50 and V1 mounts and they are in stock.
My email is mike3348@adelphia.net
Mike
Old Jan 12, 2006 | 04:58 PM
  #153
yeperra's Avatar
yeperra
Just got my mount yesterday. Nice work Mike and THANKS!
Old Jan 25, 2006 | 06:03 PM
  #154
lamaz's Avatar
lamaz
I just ordered my mount from Mike (BTW Mike, I meant to say it's the x50 not the old 8500). So the mechanicals are out of the way.
Now, on to the electricals. Does anybody know what kind of connector the auto mirror uses? If it is a molex minifit (two rows of 8 connectors). Then I can probably get those from work and make some sort of Y adapter that wouldn't require anybody to do anykind of crimping, soldering, you name it. Simply plug and play.
Can anybody get access to the pinout of the connector that hooks up to the mirror, and possible some close pictures of the connector that goes into the mirror? My roadster has the cover on it all winter, and I'm too lazy to take it out to take a closer look.
-LamaZ
Old Jan 25, 2006 | 06:17 PM
  #155
lamaz's Avatar
lamaz
OK answered my own question about the pinout.
Only thing left is to find out the actual connector. Hmmm, I've had custom cables made before at work... wonder how good these would sell. Mike, maybe we can work something out to provide a complete solution that doesn't require any splicing or mechanical mods to the car.
FYI, here is what I found. This is from the 2004 service manual.
-LamaZ
Old Jan 25, 2006 | 06:26 PM
  #156
lamaz's Avatar
lamaz
OK, technically I'm now officially post whoring... but I think it's for a good cause.
Anybody who works for Nissan and understands their wiring diagram conventions please double check my understanding of this diagram.
Pinout for connector R4 (the mirror) is:
Pin color description
5 blk/org 12V fused battery direct
6 blk/red 12V fused after ignition switch
8 blk earth ground
*if it's not labeled, then I'm guessing it's not connected anywhere.
-LamaZ
Old Feb 1, 2006 | 05:47 AM
  #157
lamaz's Avatar
lamaz
...bump...
I've been doing my research. It turns out that the Z comes with a mirror made by Gentex. I beleive the model number is 50-GENK40. I've contacted Gentex to see if I can find out what the wiring harnes part number is.
The pictures I took of the connector weren't in focus, so that's of no use.
I'll probably keep updating this thread and talking to myself once I find out.
-LamaZ
Old Feb 1, 2006 | 05:55 AM
  #158
maxwell72764's Avatar
maxwell72764
Hey lamaz,
If you come up with a 'Y' adapter for this, I would be very interested. I spliced in to my harness without cutting into the wires but my solder job was not up to snuff. After about a year, I lost power to the detector. Mirror still works fine but I'm too lazy to redo it. Keep up the work and us posted.
Maxwell
Old Feb 1, 2006 | 11:32 AM
  #159
lamaz's Avatar
lamaz
Somebody that has access to Nissan information needs to help us out. I've tried calling Gentex and finding out what the part number is, they referred me to Mito Corp (distributor). Mito doesn't want to give out the info.
Gentex did tell me that the connector (or harness) is made by Sumitomo. I've called Sumitomo and have had no reply yet.
So if Nissan can give us the Sumitomo part number for Nissan 350Z Connector R4. Then we are all set.
Help us out!
-LamaZ
Old Feb 2, 2006 | 07:56 AM
  #160
lamaz's Avatar
lamaz
Well, I'm close to giving up on trying to get the part number for the connector. This option isn't pretty, but it's looking alot more appealing.
-LamaZ
