Need help ASAP please!!!
Old Oct 19, 2003 | 05:58 PM
wren57's Avatar
wren57
Default Need help ASAP please!!!
Since installing my system a while back, under heavy bass the passenger rear speaker has rattled badly. Just tonight I got around to looking at it. When the speaker hits hard, it touches against the plastic speaker cover and makes a terrible rattling noise that destroys the quality of the sound. Is there any way to fix this? Can I remove the speaker cover any way?
PS- I have some fatmat between the speaker and the speaker mount so it's mounting height is a little bit more than without the fatmat. Removing the fatmat might work as it would lower the mounting height, but I don't want to lose the vibration dampening qualities it gives...
Old Oct 19, 2003 | 07:07 PM
fresno350's Avatar
fresno350
i think your gonna have to remove it. the fatmat
Old Oct 19, 2003 | 08:19 PM
wren57's Avatar
wren57
OK- the fatmat between the metal speaker hole and the speaker is gone, but the rattle is STILL there!!! It is so annoying and seems to be getting worse. I know it is because the speaker surround hits the grill on full excursion during heavy bass... is there any way to remove the grill? Would I have to cut? Would it look like crap? Any other ideas? I'm tired of rattles... thanks.
Old Oct 20, 2003 | 04:28 PM
wren57's Avatar
wren57
^bump... this rattle is annoying...
Old Oct 20, 2003 | 07:41 PM
BigTymer8301's Avatar
BigTymer8301
check your gain settings on your 4 channel amp. make sure they are equal and you don't have one cranked and also try bumping the crossover up a little bit and cut some of those lower frequencies out of that speaker. these would be the first couple of things i'd try/check at my shop. hope this works.
etkms
Jun 19, 2022 06:30 PM
LunchBox20
Oct 20, 2015 10:22 PM
