Stock HU - FM tuner wont come on
Old Jan 5, 2010 | 06:32 AM
VandyZ's Avatar
VandyZ
Default Stock HU - FM tuner wont come on
I drove my Z for the first time in a month over the weekend and the FM radio would not work. CD worked, AM works, but it wont switch to FM. If the radio is off or CD is playing and i push the FM button, the AM tuner comes on.
I the battery has died a few times the past couple months. I have been using a battery tender to keep it charged recently.
Has anyone ever had this happen? Is there a reset anyone knows about?
Old Jan 5, 2010 | 08:25 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
FM on my Bose won't pick up any stations all of a sudden. It fades in and out. I got behind there and checked the wires but nothing seems out of place
I haven't checked AM.
Old Jan 5, 2010 | 08:51 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
The AM, FM, and CD players all use the same input power and outputs so it would seem your headend is dead. Before throwing it out you could try disconnecting power and reapplying the power to see if it resets the internal logic.
Old Jan 5, 2010 | 08:53 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Check the AM as well - did you check the little tiny RF amplifier that's mounted in the trunk under the antenna? There's a little antenna booster back there and when folks change out their stock headends they often forget to provide power back there to light up that amplifier and get the sort of symptoms you're describing.
Old Jan 5, 2010 | 08:58 AM
AdvanZ33's Avatar
AdvanZ33
I'll go check it out right meow.
Old Jan 5, 2010 | 09:00 AM
AdvanZ33's Avatar
AdvanZ33
BTW OP, not trying to jack your thread. Just felt I had a similar problem
Old Jan 5, 2010 | 09:09 AM
VandyZ's Avatar
VandyZ
NP . . . i just thought it was weird. I could sort of expect the button to break over time or the entire thing stop working, but everything is fine except for FM. It will not swap over to the FM tuner. The FM tuner button pushes and clicks but activates the AM tuner so i know the head unit registers the button press. It is very strange.
Old Jan 5, 2010 | 09:23 AM
AdvanZ33's Avatar
AdvanZ33
AM/FM is all static and won't pick up any stations when I "seek." I'm going to wait until I get home before I start removing panels to get to the antenna. Also, at the same time my radio stopped working my clock stopped as well. It still reads the time and I can set the time but it won't roll over to the next minute.
Old Jan 5, 2010 | 02:39 PM
duro78's Avatar
duro78
Ill send u mine for 35 shipped
Old Jan 6, 2010 | 06:00 AM
VandyZ's Avatar
VandyZ
Is it from an 04 or 04.5? The reason why i ask, is the 04.5 switched to black plastic front from the color-matched grey of the 03's.
Old Jan 6, 2010 | 07:03 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Yikes ... that sounds like the logic brain of your head end is tweaked.
Time for a replacement or upgrade?
Old Jan 6, 2010 | 08:57 AM
AdvanZ33's Avatar
AdvanZ33
From what I'm reading, upgrading the Bose HU is a pain without running a module. Maybe just replace it and add an Ipod adapter. BTW, it's always 3:50 in my car haha. I'm a dork.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
