nav install to media receiver?/
hey all,
I am planning to install an aftermarket hu. I first was looking at some dvd and navigation headunits but the thing is i never watch dvds. All I need for an aftermarket hu is to hook it up to a usb thumb drive and listen to mp3 music. Also, I would prefer having a navigation system as well. So I was wondering if i buy one of the alpine's media receiver headunits, which has a screen, can I somehow hook up a navigation system to work on the screen? Has anyone done this setup? Any suggestion is appreciated! Thanks, |
Like the Alpine iVA-W203 with the optional NVE-P1 navigation module?
I don't know the specific model number but the one you are talking sounds right.
Also, I've seen some poeple having two screens, one inside the cubby. CAn I use two screens to have nav on all the time, so I don't have to go back and forth from audio to nav?
Thanks in advance |
Originally Posted by bbak11010
(Post 8087137)
Thanks in advance Depending on what year Z you have, it might be easy to just place a 7" monitor in the cubby. For the 03-05 models you can take the cubby out and mount the screen in its place. The 06+ models that came without navigation require either an entire new bezel from a navigation model or some custom fabrication. It is extremely hard to keep the cubby and put a full size monitor in there. If you have no need for for the ability to play DVDs, you might want to consider going with a single DIN in the stock radio location. No need in spending more money on a double DIN if you don't need it. |
(Post 8086349)
hey all,
(Post 8087137)
Thanks in advance
Here are the two components you need to have navigation in your upper/forward cubby: NVE-M300 GPS Navigation Drive http://i123.photobucket.com/albums/o...M300GPSNav.jpg http://www.alpine-usa.com/product/view/nve-m300 Alpine TME-M770 6.5” LCD Monitor. http://i123.photobucket.com/albums/o...b/TME-S370.jpg http://www.alpine-usa.com/product/view/tme-s370 If you want a second LCD screen, use one of the compatible Alpine double-din H/U’s. If you don’t want a second LCD screen, use either the Alpine TME-M770 6.5” LCD Monitor (in the upper/forward cubby) along with one of the compatible Alpine single-din H/U’s, or use one of Alpines double-din devices with an LCD screen. Notice that the Alpine NVE-M300 GPS Navigation Drive can display its image on the Alpine TME-M770 6.5” LCD Monitor (on which you can operate the navigation device using the touch-screen functions on the TME-M770). Or, you can simple connect the NVE-M300 GPS Navigation Drive to one of Alpine’s compatible double-din LCD touch-screen H/U’s. The links I posted provide a list of compatible devices. Important Note: Installing the TME-M770 6.5” LCD Monitor in the upper/forward cubby may require a minor amount of custom fabrication depending upon the model year of your Z. Hope this is helpful, :) --Spike |
Once again, Spike proves to be the man!
Originally Posted by JEKL
(Post 8091643)
Something I didn’t do in this post (and it’s obvious and “screaming” by its omission) is a comparison of Kenwood’s KOS system with Alpine’s new line of products.
--Spike |
thanks, some more questions
Thanks Spile for your information. It really helps me alot to understand my options.
I never experienced Kenwood, but I do hear alot of good things about them. As of now, I am not really set on one item so if someone like you who are knowledgable in this audio area recommends me something, then I will probably go that way. haha I have a 04 touring. Should've mentioned that in the beginning. Can you give me some specific item numbers from Kenwood so I can look them up and compare/purchase them? I really become frustrated trying to compare tons of products when Im searching around. Also, since this is my first time installing a hu for a z, what are some other accessories that I need to purchase at the same time? I am thinking a harness, and a bezel, but is there anything else I should get? Also, can someone help me where I can get the harness, and an item number for it? Thanks everyone for your help. oh, Im actually looking for a hu with usb input.. i don't use iphone or iPod.
Originally Posted by Spike100
(Post 8091812)
Thanks for kind words.
--Spike |
Here is a write up on my Kenwood CarPortal. The Kenwood KOS unit allows USB input.
https://my350z.com/forum/audio-and-v...r-install.html |
(Post 8093786)
[ … ] I have a 04 touring. Should've mentioned that in the beginning.
Can you give me some specific item numbers from Kenwood so I can look them up and compare/purchase them? I really become frustrated trying to compare tons of products when Im searching around. [ … ] You should also read Paul350Z’s thread that demonstrates mounting an LCD screen in the Z’s upper/forward cubby. https://my350z.com/forum/audio-build...tallation.html. This thread describes mounting an LCD screen in a 2004 Z, but the principle applies to any model year Z.
(Post 8093786)
[ … ] Also, since this is my first time installing a hu for a z, what are some other accessories that I need to purchase at the same time?
I am thinking a harness, and a bezel, but is there anything else I should get? Also, can someone help me where I can get the harness, and an item number for it? Thanks everyone for your help. oh, Im actually looking for a hu with usb input.. i don't use iphone or iPod. Crutchfield (crutchfield.com) is a good source for harnesses and mounting kits (and all of your A/V needs for that matter). Some members say Crutchfield is expensive, but the support you get here is terrific. Crutchfield supplies the right parts, the first time; and the support staff helps you get this stuff installed correctly. --Spike |
thanks guys, it was definitely helpful. I will start building my system and hopefully get some pics up soon.
Thanks again, |
I was actually looking at alpine media receivers, single din. I can make this simple and go with just one screen in the cubby. but to these head unit have video out?
What are some single din headunits that i might be able to hook it up to a lcd monitor, has usb input, and adapts nav? is there anything like this? or to get everything i want, is going with a double din my only option? So many questions, sorry guys. |
(Post 8095304)
What are some single din headunits that i might be able to hook it up to a lcd monitor, has usb input, and adapts nav? is there anything like this? or to get everything i want, is going with a double din my only option? So many questions, sorry guys. There are two trends in intermediate/high-end car CES:
All-In-One Devices These are double-din devices that contain or support everything. They typically have a 6.5” – 7” LCD touch screen for display and operation, a DVD player (or a connection for a remote DVD changer), iPod connection/support, a USB port, built-in navigation (or a port to connect a Navigation Black Box), built-in amplifier, pre-outs for external amps, rearview camera, etc. Advantages:
Disadvantages:
Modular Digital Systems This is a collection of separate components you install and connect to a remote monitor you fit into the Z’s upper/forward cubby. The remote LCD touch screen monitor is “command central” for the entire CES and all the components you have in your CES. The components are an H/U, along with any optional devices you want (DVD player, navigation, rearview camera, external amps, etc.). The system can use either a single-din or double-din H/U. Advantages:
I realize you request specific information and model numbers, but it’s more complicated than that. I could go on and on ...and on ...listing different solutions with various components. You need to do some research here to get exactly what you want. Hope this helps and does not just add more confusion, --Spike |
Thank you!
Thanks alot Spike!
I gotta say this that everytime i read your information and explanations they are awesome. It really helps alot for someone like me who is starting to get into all these audio/video stuff. Like you said, I will do some more homework and studying. I think I will reroute my way and go with your second option with a single din. Thanks! John
(Post 8097952)
Single-din receivers are the best. You get a lot more value with a single-din receiver. It's interesting, but not surprising, that the better single-din receivers are going sans CD players in more recent and better models.
Disadvantages:
