Farenheit Screen has some "burn in"
Old Oct 24, 2003 | 02:38 PM
rouxeny's Avatar
rouxeny
Default Farenheit Screen has some "burn in"
I've had my screen for over half a year and I noticed that there's a small area of "burn in" appearing. I'm not sure I'm using the term correctly, what I mean is the resideual image you see when a screen displays the same image for prolonged periods of time. You know, the whole reason screen savers were originally invented.
It appears in the upper right of my screen. When the nav is on, there's a small circle with an arrow in it, acting as a compass. It, unlike everything else on the screen, never changes position or changes numbers or other information.
It's a very little area, I just hope it doesn't get worse. I'll try playing some DVD's on the screen to see if I can tell then.
Other than that, the screen is working fine.
Old Oct 28, 2003 | 06:47 PM
alphared's Avatar
alphared
uh, LCD screen can't have "burn in" It only applies to projection CRT screen where the Screen is constantly bombarded with rays (so a fixed image will be burnt in to the screen) I think its a screen defect, more likely "ghosting" cause refresh rate isn't fast enough. looks like signs of dead pixels (you might get black or white dots in that area soon)
apex locator
Jul 23, 2021 02:27 AM
Workshop12
Mar 23, 2020 01:45 PM
jlb
Oct 15, 2017 05:10 AM
allmycarsdie
May 13, 2016 04:38 PM
Tochigi_236
Sep 27, 2015 03:40 PM
