How To: Put a 10'' sub in the factory location
So I was looking for a way to fit a sub into the factory cut out and realized i could use the back of the bose sub as an adapter ring...
This is the sub after i pried it apart and cut the back ring off with a pair of tin snips
Here is the cut ring and the sub that is going in...
Here is how the sub sits in the ring, LIKE A GLOVE
Then just bolt the sub to the ring and then bolt the ring in using the factory hardware and you are good to go!!!
It works great and looks good as well, an installed picture will come tomorrow as its getting dark now
I did this myself, to mount a JL W0 I didn't use the mounting ring though. I bent out the folded over metal. Drilled my own holes. I used double sided stuff to seal the actual sub to the "box" I used ALOT of Dynamat to close in the box. I took up airspace by sticking 3 pillows inside the box. I mounted an Alpine amp in the "glove box"
Dude i commend you for trying but it is evident your not too familiar with car audio. You can not make an enclosure like that. I see you just got the car so you might not know members were trying to do this 5-6 years ago its been done to death with
failed results each time. So stop while your ahead and stop wasting your time and please dont finish the project and come back on and say it sounds good because we all know better. You cant just throw any sub in what may seem like a box and expect it to sound good.
polyfill or pillows would make the box seem larger to the sub then if there was no fill used. it slows down the sound waves with makes the space seem larger. if you could find a free air sub then this method would work fine, but with most subs you will need a defined box.
The type SubW you are installing will sound awful unless you seal the space. Loading the space with filler isn't the solution, and it might only make things worse.
--Spike
Point #1
The woofer needs to be seals 100% completely totally air tight. A quick check is to gently press the woofer down to it's retraction point - about an inch for a bigger woofer. You should feel the pressure pushing back ... hold for about 20-30 seconds and then release - the woofer should spring back quickly. Even a pin hole air leak is bad. Sealed woofer means sealed. An unsealed woofer is sloppy and distorted and in can actually cause the woofer to shake itself to death.
Point #2
There is a bunch of science behind the design of a subwoofer. I've posted many (many) times before but the bottom line is that they're carefully designed to operate in a given volume of air. For most 8" to 10" woofers that range is about 0.5 cubic feet to about 1.25 cubic feet - what sounds good at 0.5 is going to sound bad at 1.25. If the woofer is designed around 0.75 then up or down a bit is OK for taste ... but stay too far and a good woofer sure sounds bad.
Respect the manufacturer of the woofer and do it justice by putting it in a sealed enclosure of a proper size please.
Point #2
^^ Paul,
Great points. As usual you provide advice with specific instructions and facts.
Something I had not considered that you point out…
…is absolutely true. If you mount a SubW designed for a sealed compartment, and you simply “poly-fill” the space (instead of an airtight seal); you can expect this:
--Spike
Great points. As usual you provide advice with specific instructions and facts.Something I had not considered that you point out…
- Best case: The Subw will sound poorly, and it will eventually shake the mount loose.
- Worst case (and an eventual certainty): The SubW will be irreversibly damaged (i.e., “Shaken SubW Syndrome”
--Spike
Tochigi_236
Sep 27, 2015 03:40 PM
