I need some help/suggestions with stereo setup! Also, stealth sub box
Old Mar 27, 2010 | 07:44 PM
platinum350's Avatar
platinum350
Default I need some help/suggestions with stereo setup! Also, stealth sub box
Ok, so i'm starting to get frustrated trying to put my simple system together, i've done much research but there is just so much out there.
Wanna purchase the Pioneer AVH-P4100DVD head unit but need help with the rest.
Front speakers: Not sure, looking for a nice mid level component set and would like to keep the tweeters in the OEM location.
Rear Speakers: Going to leave disconnected.
Sub: I have a fiberglass corner stealth type enclosure that I bought on here and they recommended an Image Dynamics 10" sub, just not sure which one to get??
Amp(s): Ok, this is where i'm having most of my problems. I have a new Sony X-plod XM-2165GTX 1000 watt 2/1 channel amp 330x2 max power 165x2 RMS laying around, not sure if I should even use it.
Otherwise, like a lot of the Alpine amps.
Need suggestions on this though; should I get a mono sub amp and another amp to power my fronts? Should I get ONE multi channel amp to power my sub and the fronts?
Any help appreciated!
Old Mar 28, 2010 | 02:18 AM
duro78's Avatar
duro78
register on caraudio.com and start reading
Old Mar 28, 2010 | 10:20 AM
platinum350
ok.
Is there any advantage/disadvantage by using 1 4 channel amp to power the front speakers and bridging the rear two channels to power the sub Vs. 1 2 ch amp powering the fronts and 1 mono amp powering the sub? Besides cost and more to hook up.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
