AVH-4200 wiring to non-Bose
Old May 18, 2010 | 09:08 AM
AlT's Avatar
AlT
Default AVH-4200 wiring to non-Bose
Hi All,
This forum has loads of info! I haven't install a car stereo in years. But the non-bose system is better when turned off. I like to listen to music sometimes, so I just installed a Pioneer AVH-4200DVD along with new speakers front and rear with a Infinity Basslink behind the driver's seat. It now sounds a million times better.
This is a quick schematic of the interface between the stock 350z wiring, Metra 70-7550 harness and Pioneer AVH-4200DVD (it will work for other Pioneer models as well).
I used a spdt switch from Radio Shack for the DVD bypass, I didn't want to do the relay method because I would have to bypass it if I want to use the Auto Eq. I have a microphone on order, anyone have any experience with Auto Eq? There isn't much info on it's use in the manual.
File Type: pdf
Old Mar 8, 2011 | 06:31 PM
warrior86's Avatar
warrior86
hey man! were you able to get the MIC and hook up the auto eq while still having the relay connected? I wasnt and I was wondering if you found a working solution, like some kind of switch or something.
Old Mar 8, 2011 | 08:51 PM
AlT's Avatar
AlT
Didn't use a relay. A switch was used to enable the DVD function (light green wire) on the 4200. AutoEq works great!!
Old May 15, 2011 | 09:46 AM
my friend's Avatar
my friend
i'm currently installing avh-4300 and i have few questions
do i need to do something with the amp wires if i dont have an amp?
also what do i do with mute and reverse wires black/yellow and purple/white?
and lastly do i just plug in a switch and ground it at the parking brake? or anywhere?
Old May 16, 2011 | 08:32 PM
AlT's Avatar
AlT
AVH-4200 and AVH-4300 harness wiring is the same. Black/yellow (mute) and violet/white (backup camera) not used. If you don't have an amp and don't hook up a camera. Use a spdt switch to connect the green wire from you radio harness to ground. Good luck.
Old May 17, 2011 | 07:01 PM
my friend's Avatar
my friend
thank you for all your help.
350Z_Al
Oct 29, 2020 07:44 PM
bcoffee20
Nov 19, 2015 06:39 PM
nanotech
Oct 2, 2015 05:02 AM
cashmoney03
Sep 27, 2015 05:24 PM
Beater350z
Sep 9, 2015 03:36 PM
