Bose Subwoofer Problems
Old Jul 15, 2010 | 11:11 AM
CaseyG3's Avatar
CaseyG3
Default Bose Subwoofer Problems
I just bought my second replacement subwoofer today and am already having problems with it. After installing it, I kept the music down low and gradually increased it for about 15 mins and then I turned it up to the normal volume i usually have it at. I went to change my EQ settings and the subwoofer screeched and then played very loud static that sounds like thunder. When this happened, even after i turned it down it still sounded like the sub had blown out. Even at 0 volume it was crackling. I have an stock everything besides an aftermarket HU (Pioneer Premier) but I dont think that should affect the power going to the subwoofer. Is there something I am missing or did I not give it proper time to warm up?
Old Jul 15, 2010 | 12:41 PM
NttnbutaZthang's Avatar
NttnbutaZthang
this will most likely get moved....sounds like a blown amp....there is a little sub amp mounted to the back of the sub bracket...i would give u mine but i chucked it
Old Jul 15, 2010 | 01:14 PM
LVZ053's Avatar
LVZ053
There is a DIY on how to fix a bad amp, it has a lose connector. I had the same issue and it worked on my car, only took 5 mins.
Old Jul 15, 2010 | 01:24 PM
Welcome.
1. The woofer amplifier is broken.
2. Feedback from woofer amplifier broke the head unit.
Old Jul 15, 2010 | 02:14 PM
richcity's Avatar
richcity
Is there any way to test the amp or the subwoofer to know for sure if that's the problem?
Old Jul 18, 2010 | 11:21 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Feed a clean sine wave on pins 1 and 2, I'd try 0.25 volts to 1.0 volts, and measure the output with an oscilloscope on pins 3 and 4 across a 2-4 ohm load.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
