Hardwire Radar Ground Location?
Old Nov 10, 2003 | 12:47 PM
Grudus's Avatar
Grudus
Default Hardwire Radar Ground Location?
This weekend after I installed my Passport 8500 using Mike's nifty Bracket I started looking at what is involved in doing a hardwire install to the fuse box. I picked up a Littel Add-A-Fuse from Autozone to tap into the fuse box. Then I started looking for a good place to put the ground. I didn't see any place that looked like a good spot. Was wondering what everyone else was using for a ground spot?
Old Nov 10, 2003 | 02:40 PM
Grudus's Avatar
Grudus
Finally found a good spot to put the ground disregard the above post.
Old Jun 20, 2004 | 07:07 AM
jhchan's Avatar
jhchan
Hello,
I am doing the same install except with a Valentine 1. Where did you end up putting your ground around the fuse box?
Also what is the add-a-fuse thing you got? I got these fuse tapes from radio shack which was this metal piece that wedges in with the fuse. I actually had to cut off half the connecter that loops around the fuse because it wouldn't jam in. Wondering if your thing might be a better way to do it. Thanks!
Stevo Z
Oct 3, 2015 09:14 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
Tochigi_236
Sep 27, 2015 03:40 PM
