Sonicelectronix 10in Sonic Sub Box?
Old Jul 26, 2010 | 02:04 PM
STL 350Z's Avatar
STL 350Z
Default Sonicelectronix 10in Sonic Sub Box?
Anyone have any experience with this under strut box or should I stick with Zenclosures under strut box?
http://www.sonicelectronix.com/item_...NIS350-10.html
Old Jul 26, 2010 | 03:14 PM
duro78's Avatar
duro78
stick with zenclosure top notch
Old Aug 7, 2010 | 11:50 PM
STL 350Z's Avatar
STL 350Z
I have a brand new 10in Rockford Fosgate P2 sub and max sealed for this sub is 0.85cf. The zenclosures is 0.75cf so what would be the difference in sound between 0.75cf and 0.85cf?
Old Aug 8, 2010 | 07:43 AM
devildriver421's Avatar
devildriver421
.85 will get lower/louder. Whether or not it's noticeable I can't say. It also depends alot on other factors too though.
Old Aug 8, 2010 | 09:38 AM
STL 350Z's Avatar
STL 350Z
I am going for sound quality so what would you all recommend as far as the box? it's going to be getting 250-300'ish rms.
Old Aug 8, 2010 | 09:48 AM
idkorcare's Avatar
idkorcare
Either one of those will probably be fine. You might just add some polyfil. Both boxes are the same design and airspace if I remember but that if there is a difference its going to be minimal and most likely you arent going to be able to tell. If they are the same price I would go with the Zen, they make it. The sonic one is most likely made by someone else.
Old Aug 8, 2010 | 12:30 PM
STL 350Z's Avatar
STL 350Z
Thanks a lot guys I appreciate it.
Old Aug 8, 2010 | 12:41 PM
350zspl's Avatar
350zspl
your not going to hear a difference with such a minimal difference in size
boxes slightly to small allow for using more power
a box to big will get louder off less power
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
