door output?
no one knows?
After some diggin in the service manual, found out that our security/keyless system is tied to a BCM that controls the doors, horns, lights, etc.. , but can't seem to find if the doors locking is set off by a negative pulse or postive.
Reading this, raised another question. Will disconnecting the BCM affect the car's ECU in anyway?
Originally posted by Encore
The Z has negative door lock, and negative double pulse unlock. You do not need to disconnect the BCM to install a alarm.
Then you would have 2 alarms. Whats the harm in that. The only thing special you would have to do is if you plan on doing remote start you need to hook up the "factory disarm" wire from your AM alarm to the disarm wire on the OEM alarm. That way it want set off the factory alarm when you remote start.
m_0g
Jun 3, 2021 10:05 AM
