What do you think?
I'm going to attempt install this weekend.
http://www.paragonwest.com:8080/350zmods/mysetup.htm
I still don't know exactly where I will put the amp, it's like 32 inches long! I want to be able to make adjustments reguarly so behind the seats might get difficult for this. I have the sub in a box for know and I am thinking I will put it some where in the hatch area but will consider behind the driver's seat if I can make the box fit.
Any advice on placement of amp or sub would be appreciated.
Thanks!
Thanks!
My JL Audio 10w6v2 sounds really good in this position...in a custom fiberglass enclosure built to JL's specs. The factory location is not the best choice for sub location, try moving it to the hatch if at all possible.
It will be difficult to fit an amp that big anywhere in a car this small. You could maybe build something under the strut tower bar, then mount the amp to the other side. If you don't mind losing the spare you could probably build both of them into the floor.
