Crimp Tool Selection Help
Old Sep 14, 2010 | 12:41 PM
xthejokerx's Avatar
xthejokerx
Default Crimp Tool Selection Help
Hello,
I have a 24 gauge wire that needs to be crimped onto a bullet connector and selecting the right crimp tool is actually a lot harder than I thought. I thought it was just simply selecting a crimp tool that fits the gauge requirement and voila, but there's actually crimp tools for different types of terminals, etc...
Here's the bullet connector I'm trying to crimp bare wire onto:
And here's the parts I want to crimp:
Basically, my selection of tools comes down to all the items inside these two catalogs.
http://www.jameco.com/Jameco/Products/ProdDS/99443.pdf
http://www.jameco.com/Jameco/Products/ProdDS/308030.pdf
Can anyone please tell me if any of the products I've listed will work?
Old Sep 14, 2010 | 01:13 PM
350zspl's Avatar
350zspl
i have 3 crimp tools
but i install
i use a klein 10-22 awg found at home depot for about $18- $25 red handle has wire cutters at the tip
i use a klein that does 10-16 awg in one cut out and 18 awg to 24 awg in the other cut out with black handle has wire cutter at the tip $19 - $27
i use a Matco orange handle 10 awg to 22 awg $ 40 - $55 has wire cutters at the tip
all would work on the connectors your trying to crimp
Old Sep 18, 2010 | 10:22 AM
KPierson's Avatar
KPierson
How many do you have to do? I have had very good luck with using needle nose pliers to do a few of those at a time.
Out of the two you posted I would go with the 99443. However, I would also recommend finding a crimper that will do both crimps at the same time. If you have the model number of the crimp you are using you should be able to find the manufacturer tool for that exact terminal.
Molex also makes a universal crimper that is similar to that 99443, you may want to consider it. It only does a single section as well.
Workshop12
Mar 23, 2020 01:45 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
