Help With Double Din Kit
Old Oct 28, 2010 | 05:50 PM
BxPrettiBoii's Avatar
BxPrettiBoii
Default Help With Double Din Kit
I just Installed a Pioneer AVH-P3200BT radio on my 04 Z
the people who installed it ordered the double din kit but
when radio was placed in it there was to much gap on top and bottom;
They returned the piece and custom cut some plastic for the mean time
until i can find a better fitting Kit;
Any one have any suggestions?
Old Oct 28, 2010 | 06:00 PM
Ak48z's Avatar
Ak48z
Might try a different brand for the dash kit. I have the same pioneer and mine didn't fit 100% either, I got it evened out for the most part though, cant tell unless you really look at it.
Old Oct 28, 2010 | 06:15 PM
bmccann101's Avatar
bmccann101
unclear.. are you installing a double din, or are you referring to a double din sized kit for a normal deck?
Metra kits should be spot on.. other brands, ah so so.
If you are instaling a double din... there will be NO gap.. use your factory brackets.
I did have to redrill my holes on the metal brackets back .25 in to make it flush and to not stick OUT, but theres no gap.
Old Oct 29, 2010 | 01:09 PM
BillytheKid's Avatar
BillytheKid
i had the same issue with the metra kit. my pioneer 4200 wouldnt fit flush. i ordered a scosche kit and it fit fine.
EnjukuRacing
Sep 30, 2015 06:55 AM
