Help Identify Wires- pics inside
Hey guys,
So i stared for hours at a wiring diagram from the service manual and it mentions left rear speaker +/- and right rear speaker +/- colors that I do not see. Can someone identify left rear +/- and right rear +/- looking at this. I want to obtain my line out RCA signal off those wires.
Thanks.
Thanks.
Hey guys,
Thanks.
Thanks.
Unless your amplifier is designed to accept a high level signal on the low level (RCA) inputs it's not going to work right, and you risk damaging your amp. Very few amps are designed to do this.
You will more than likely need a "line output converter"... What is does is convert the high level (speaker level) signals to a lower voltage, low level signal (RCA). A very popular inexpensive one is the "Trunk-LOC" made by PAC Audio. You'll spend anywhere from $30-50 for a line output converter. Most car audio shops will have one in stock, and know what you are talking about if you go in and ask for one.
These are the wire colors I have on file for the rear speaker signals from the deck:
2003/04/05:
LR Speaker +/- lt. green/red - black/yellow
RR Speaker +/- blue/orange - black/pink
2006/07:
Note:Also brown - black/red on some models.
Note:Also blue - pink on some models.
If you have any other questions send me a PM. I've been a professional installer for many years
350Z_Al
Oct 29, 2020 07:44 PM
Justin100
Nov 29, 2015 03:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Tochigi_236
Sep 27, 2015 03:40 PM
