Crossover Mount Location - Diamond Audio
I have recently purchased the Diamond Audio D363.5 components for my fronts...the crossover seems rather large...
will I have trouble finding a place to mount the crossover within the door...and unfortunately it has to be mounted within the door as I will not be drilling into the molex and passing in new wires (power will be up to only 70W RMS)
has anyone else mounted these crossovers and where would be a good place...thanks...
Alright first of all 18AWG should take 200w like we talked about earlier, so it doesn't really matter if they're in the doors or not. Secondly you can mount them in inside with 3M double-sided mounting tape or carefully with metal screws. Otherwise tap the speaker lines before they go through the door sleeve and put your crossovers behind the kick panels in the floorboard.
i just installed some Alpine type-r's last week. i decided it would be best to use heavy duty 3m double sided and mount the crossovers inside the doors. I mounted them above the woofer/vertically (again, inside the door). Seems to have worked out well.
The only negative now is i pretty much have no simple way to access the crossover if i was to want to make any adjustments physically on the actual crossover. Luckily my HU is packed with tuning options, so its a moot point in my case.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
Tochigi_236
Sep 27, 2015 03:40 PM
