audio and video q's for you geniuses!
Old Nov 20, 2003 | 07:09 PM
mario60185's Avatar
mario60185
Chicago Realtor
Question audio and video q's for you geniuses!
ok ....i am going to be purchasins and installing soon an all new system..first a few questions...im installing new fosgate components in front and new rear speakers and will power them with an amp..sorry if this is confusing but ive never installed any car stereo before...anyway, are the factory speaker wires ok to use or should i go through all the trouble of rewiring? if so what kind of wires?
ok now to the hard part. ill tell you what exactly im getting or have and i need your advice what to do..
1. head unit ( dont have yet, what kind of inputs or outputs do i need?)
2. probably the farenheight dvd player. ( what wiring do i need?)
3. xenarc or farenheight 7" screen ( does it come with necessary wiring?)
4. fosgate components in front and fosgate in rear( i think both are about 75-90 watts rms, can i use factory wires?)
5. one or two 10" subs, from the looks of it everyone is using jl's so i might get those.
6. i have 2 older amps, and 1 will be for the inside speakers and one will be for the sub/'s
Is that all i need? will everything work o.k? any advice, tips, or anything is appreciated greatly. please remember i am a complete idiot as to actual wiring of any of this but if you put your mind to it you can do anything right!
Old Nov 20, 2003 | 07:29 PM
Frisco's Avatar
Frisco
Mario, I had the same questions on the wiring. Do a search on my name in this forum and you'll find some good info. Basically yes you are fine with your current gauge wire.
Old Nov 20, 2003 | 07:39 PM
bastard's Avatar
bastard
I'd look in to a headunit with 3 pair of RCA outputs--front, rear, sub--so you have use of a fader. Factory wiring is fine for all speakers. I assume you are going to install the amps in the spot behind driver's seat? If so, just run new wire for rears (it's easy to do) and run speaker wires up to behind the h/u for the fronts. Get a headunit with an aux input. You can just patch in the sound output from the dvd straight into it without having to use a silly modulator. I installed a single JL 10w7 and it's like the perfect amount of bass--loud as **** in the car and you can barely hear it outside--low key.
Old Nov 21, 2003 | 06:38 AM
mario60185's Avatar
mario60185
Chicago Realtor
Default im confused
are you saying that i should run new wire for my speakers ( components and rears? or no
thanks for the help
Old Nov 21, 2003 | 06:46 AM
mario60185's Avatar
mario60185
Chicago Realtor
Default search
thanks for the help i really appreciate it but how do i do a search on your name ? i put your name in the search button but nothing about wiring came up?
Old Nov 21, 2003 | 08:25 AM
Frisco's Avatar
Frisco
look here:
https://my350z.com/forum/showthread....threadid=46154
look at grutter's response. And make sure that you realize that when he means max current he means amperage, not wattage.
Justin100
Nov 29, 2015 03:58 PM
bcoffee20
Nov 19, 2015 06:39 PM
350zrn35
Photoshop
Sep 14, 2015 06:53 PM
Red G Coupe
Videos
Sep 8, 2015 08:36 AM
