Questions on Locating Subs in a Roadster
Old Mar 16, 2011 | 02:54 PM
oddjobbb's Avatar
oddjobbb
Default Questions on Locating Subs in a Roadster
I am getting ready to install Subs in my roadster.Would prefer to do 2 - 10" subs, but willing to do a single if needed due to space. Dont want to use the cubby behind the driver so that leaves the trunk area. Zenclosures makes a box for the roadster but its kind of bulky any one make a sleeker one? any other suggestions?
Thanks
Old Mar 16, 2011 | 04:38 PM
bmccann101's Avatar
bmccann101
no clue why you wouldnt want to use the best space for a sub in that car ( drivers side OR passengerside cubby) and instead want to just stick it in the trunk wheres theres very little common airspace exchange.
SRQ makes a mdf and fiberglass version that will fit up to a JL 13tw5.. sub can be had for 350 new and box is 120 bucks. Fully stealth. Totaly unstealable.
Old Mar 16, 2011 | 04:59 PM
oddjobbb's Avatar
oddjobbb
Thanks for your reply!!
will the sound be better with the sub in the cubby as opposed to a sub in the trunk? or at least equally good?i am not opposed to using the cubby hole as long as i can get a decent sub in there and get decent sound out of it.
Old Mar 16, 2011 | 05:10 PM
bmccann101's Avatar
bmccann101
https://my350z.com/forum/audio-video...2-jl-10w7.html
heres my current set up.. im getting RID of it to run the set up i reccomended to you. its only 20 lbs in total as well.. get a great amp and make sure you go w a JL 13tw5 ( youtube it for idea of how loud it gets) and a good amp.
Old Mar 16, 2011 | 05:17 PM
bmccann101's Avatar
bmccann101
heres some links. :
http://www.youtube.com/watch?v=Mh9NY...DD5ACB884A93F2
http://cgi.ebay.com/Nissan-350z-Coup...#ht_4832wt_802
http://cgi.ebay.com/ebaymotors/JL-Au...fAudioQ5fVideo
Old Mar 16, 2011 | 05:36 PM
oddjobbb's Avatar
oddjobbb
will that jl sub fit in the SRQ box, they list subs up to 12"?
Old Mar 16, 2011 | 05:48 PM
bmccann101's Avatar
bmccann101
Yea. It's only three inches deep. I have the srq box in my garage cut by them for this very sub. Its a common request for them.
Old Mar 16, 2011 | 06:01 PM
oddjobbb's Avatar
oddjobbb
Thanks for the info that looks like the best solution for my needs. What amp are you
going to use with this sub?
Old Mar 16, 2011 | 06:14 PM
bmccann101's Avatar
bmccann101
The amp I have is OVERKILL. You'd be happy and safe w a properly wired Alpine pdx 600.1 and if you dont need a TON of bass..even their pdx 5 channel would do great to get u started and would give u reasonable OEM sounding power ( think luxury car OEM) and u could always add a mono sub amp later. They're exactly the size of a ream of copier paper..I run a 1000.1 and a 150.4
Old Mar 16, 2011 | 06:18 PM
bmccann101's Avatar
bmccann101
Ben buying stereo gear for 20 years. I run gear that's good..and that I can install and forget about.. no breakdowns, no maintenance etc. And its 115 here in the summer
Old Mar 16, 2011 | 06:29 PM
oddjobbb's Avatar
oddjobbb
was planning on running an Alpine MRP-M500 or Alpine MRP-M1000 mono amp for powering the sub. what do you think?
Old Mar 16, 2011 | 06:33 PM
bmccann101's Avatar
bmccann101
Sure..but the pdx are digital and pull alot less current and are not much more $
Old Mar 16, 2011 | 06:41 PM
oddjobbb's Avatar
oddjobbb
thanks for all the info ill keep that in mind.
Old Mar 27, 2011 | 09:21 PM
cpatel529's Avatar
cpatel529
I have 2 10" subs in my Roadster mounted right behind the driver's and passenger sides seats. They are below the cubby and the navigation unit. Also, still have 6.5" speakers above them in the stock location. I can post some pics when I get to my car tomm. I use a 1000x1 amp to power them. Need to do some tweaking to the levels.
All my equipment is made by Crossfire.
Chirag
Old Apr 1, 2011 | 08:45 AM
Nazar's Avatar
Nazar
We are the original creators of the Glove box subwoofer enclosure. Mounting depth in our box is 5.9" which will accomodate a 10w3v3 JL AUDIO Subwoofer and many other subwoofer for a 10" size.
We do also offer this enclosure in a 13tw5 fitment.
Please don't be mislead by copies or wooden boxes.
Wicked CAS 350Z Glove Box Magic box is 100% Fiberglass and lightweight. And offers the mostamount of mounting depth for a Glove box enclosure. We do our research.
A 10w3v3 will handle 500 Watts of power. If you wanted to do 2 enclosure you can with 2x10" subs.
I will be happy to sell you the enclosures with subwoofers at a discounted rate. simply call me and i will make you happy.
Nazar 603-642-4222
Old Apr 1, 2011 | 09:32 AM
Spider Monkey's Avatar
Spider Monkey
20 years and your recommendation is JL Audio?
HAHAHOHOHEHEHAHAHA!™
Old Apr 1, 2011 | 10:09 AM
Kwame's Avatar
Kwame
^This guy has a point!
issyz
Jul 2, 2017 03:04 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
Li1ag
Sep 28, 2015 02:07 PM
