My Proposed Glove Box Install
Old Apr 22, 2011 | 12:44 PM
v-rath's Avatar
v-rath
Default My Proposed Glove Box Install
I am building a sound system, This is what I’ve already purchased.
- Sound System
o Head Unit
 Pioneer FH-P8000BT Double-Din
http://www.pioneerelectronics.com/PU...ers/FH-P8000BT
 Amazon $259 Shipped (Metra harness also, it was like 12$ or something)
o Subwoofer
 JL Audio 13TW5
http://mobile.jlaudio.com/products_s...p?series_id=30
 $ 322.50 Shipped – Ebay New
o Sub Enclosure
 350zglovebox13tw5
http://www.wickedcas.com/product.php...0&cat=8&page=1
• Price without speaker = 349 + shipping.
o Sub Amplifier
 500/1v2 Class D Monoblock
 200$ Shipped – Ebay-New
500/1v2
http://mobile.jlaudio.com/products_amps.php?amp_id=439
o Dampening
 Dynamat 10455 Xtreme Bulk Pack 9 Sheets
 Amazon – 132.99 Shipped + Roller for $15 (also Amazon)
o Installation Kit
 DB Link PK4Z 4 Gauge Power Series Amplifier Installation Kit
 Amazon $29.15 shipped
o Trim Tools
 Actron CP5011 Panel, Trim and Molding Removal Set
 Amazon $16.96
This is what I am considering purchasing:
 Custom Engine Grounding Kit + Transmission Ground
http://www.z-xtreme.com/products.html
 $79.95
I am still on the fence about what component speakers to get. As others have suggested, I am going component, I want to mount the tweeters in the windshield column above the sails. I also plan to dremel out the holes in the door panel covers.
I’d like to get probably a set of components that will complement the sub that I am putting in, I need some advice. Looking to spend around 350 on speakers and 2-3 hundred on the amp.
I’d like to mount the amps within the glove box, I’ll be looking for how others have made shelves/mounted them in there.
The only modification that I have made to this 2007 Enthusiast was a metal Undershroud cover from z-speed.com that I had to replace, the old one was smacking the highway.
The Previous owner put a nismo shifter in I think that was the only change he made...maybe I'll find others. I picked this silverstone 2007 6mt up for 18.9k otd with 36k miles on it with a 3 year powertrain warranty.
If anyone has advice on what components/amp to buy, or anything else that I am doing, please help me out. This is my first sound system that I am building, I do have Electronics experience as I work on Communications Electronics troubleshooting and repair for a living but I am looking for some input here.
Pics later, and when I do my installs.
Old Apr 22, 2011 | 01:01 PM
Ak48z's Avatar
Ak48z
I like my CDT HD comps
I like the second skin damplifier better than dynamat too but its all pretty much the same stuff when it comes down to it.
Old Apr 22, 2011 | 02:32 PM
bmccann101's Avatar
bmccann101
save some dough.. i just bought a very nice box for th same sub from srq on ebay in mdf and f glass for 120 bucks.
I run wicked CAS door pods and Boston Pro 60Ses.. id reccomend those or a set of Focals.
The most $ i spend on one item is always my front speakers. Period.
Run a decent 120 dollar coax speakers in back, and youre all set.
Old Apr 22, 2011 | 02:34 PM
bmccann101's Avatar
bmccann101
i use the factory spots for tweeters and run the door pods.. make a big diffreence having them more on axis.. but i do run Aline imprint, which is a full "room tuning" and does time correction and levels everything.
buying Nazars sub box will gain you little versus the srq version.. buying his door pods versus running stock locations however does gain you far more, and are about the same as the price diff on getting the cheaper box. Install is simple, and far easier then dremeling all thsoe holes out, for little effect as well i may add.
I ahve been doing this a very very long time as well.
Old Apr 22, 2011 | 02:45 PM
v-rath's Avatar
v-rath
I am buying the 13.5 sub tho...will it fit that enclosure?
I just got off the phone with SRQ, they will change the mounting hole for the 13.5 I just have to state that in the comments block when I order. Man, you just made my day. Period. I wanted the pods too, but I didn't know about SRQ until today when I read that other post. I called wickedcas, they changed my order over to the door pods.
So yeah I'm excited. Now...if only I could pick out my component speakers/amp.
Old Apr 22, 2011 | 03:02 PM
SparkleCityHop's Avatar
SparkleCityHop
Living in 350Z
Not to thread jack, but since you brought it up, I'm about to buy that box too. Your opinion now that it's in?
Old Apr 22, 2011 | 04:54 PM
v-rath's Avatar
v-rath
Now, say I get a JL300/4 amp to power whatever components I get. Will the cable upgrades be good for power or do I need a cap? Anyone have real world experience with around this kind of power draw?
SRQ just accidently autodialed me, while I was on the phone with them, I asked and they told me that they would add polyfill to the box when they make it for free, just to put it in the comments when I buy it. Boss.
Old Apr 22, 2011 | 05:54 PM
v-rath's Avatar
v-rath
Ok. I've settled on Polk MM6501 Components. I found them on amazon for 179 shipped. (Unless anyone can change my mind for near the same money I'm almost 2k deep in this now.) For an amp I'm looking at a JL 300/2v2 or a JL 300/4v2 I'm not sure about this. I'm not sure. I'm thinking I only need the 300/2v2 if I'm cutting out the rear speakers which is what was suggested on this forum (correct me if I am noob which I am.) I mean...after buying those I think I've pretty much bought everything I need to do this install? (aside from a cap if I need it.)
Also, are the Remote level controls reccomended for the bass amp and the component amp both or neither? Any experience? Owners, how much do you change your settings?
Old Apr 22, 2011 | 09:20 PM
Havx027's Avatar
Havx027
I'm running the MM6501's in Bing's Kickpanels. Sounds great no rattle and you don't even have to take the door apart to run wire.
Simple install but I lost my dead pedal (got used to it over time). Also running wickedCAS glove box with Image Dynamics ID10 sub, it hits plenty for me.
I suggest using RAAMAT (Raamaudio.com) vs dynamat, no smell, it's butyl rubber compound not asphalt based and I think it's cheaper. One order of BXT II was enough to enclose the stock location and rear panels. I still have sheets left over.
Be prepared to take a few days for this install, I had to remove my seats to get all that deadening material inside into the right locations.
I have a 07' as well, head unit wise maybe the Pioneer AVH4200 or 4300 would be a good choice, fits nicely with a American International kit, no need to dremel and it will not hit the kit while ejecting.
Amps - I used just home depot mdf and wooden dowels to make posts. I used the piece of square carpet material that comes inside the glove to trace the outline on the wood, cut 2 pieces, cut the dowels with a gap so the amps can circulate some air and offsetted and for easy adjustment. Added carpet just for looks even though it's inside the glove.
Amp Rack - 2 Phoenix Gold Xenon's 100.2 and a 400.1 , crossovers mounted behind the amp. Careful not to overpower the crossovers too much, they can melt (~_~).
Amp Rack inside glove (wires are a little messy)
Amp Rack Dowel/Offset post carpeted
Bing's (16psibrick) Kickpods (Most hassle free install)
Old Apr 23, 2011 | 03:39 AM
v-rath's Avatar
v-rath
Very nice looking install. Where'd you get the carpet, and did you drill through the glove box walls for wiring? I was considering putting the sub amp inside the cavity somewhere maybe attached on top of the sub box so the sub box cannot be removed without first taking the amp off the top? Not sure how much space there is in there cause I haven't opened it yet, it can't generate more heat than stacking two of them on carpet.
I like the kick panels, but I'm not sure if that's for me, I'm 6'1 with size 13 feet, my leg room is at a premium.
Old Apr 23, 2011 | 05:26 AM
Havx027's Avatar
Havx027
I bought the carpet from a local car audio shop, you can just ask to buy a few yards from any shop. You will have to take the whole glove box the amp rack is secured using a metal brace I locked down. I wouldn't suggest mounting the amp with the box, just so you can adjust and tune it to your tastes; ease of access as well. The sub box you're getting may or may not need deadening material, I was scared of rattling so I put the stuff everywhere.
You're going to have to take most of the paneling off, just search the DIY rear panel removal and you should be fine.
Leg room is a minus with the kicks.
Old Apr 23, 2011 | 06:41 AM
v-rath's Avatar
v-rath
I mean, how often do you tune your sub amp? I would think that it would be a one time thing, I was going to use the procedure on the 350zwiki site with the audio file you download or whatever.
Anyone have experience with mounting the tweeters in the door air ducts?
Old Apr 23, 2011 | 08:22 PM
chaparro78's Avatar
chaparro78
There are some good posts on tweets. Location will depend on the tweet you get. Some are meant to run on axis (pointing at you) or off axis (bouncing against windshield)
I have Focal K2Ps components, their tweets are off axis. Blew a mid range (6 1/2") a couple weeks ago. Replacing with Hertz Mille, will have to play with tweets to see if hey will sound better on/off axis
Old May 5, 2011 | 06:26 PM
v-rath's Avatar
v-rath
Still pondering on where to mount the amps.
One is going in the glove...fo sho. I have limited power tools, so I'm not thinking I can build a rack. I could put them side by side and remove the bottom tray, which should bring some air into the cubby...but I think that would just get too hot. Someone said beneath the glove box, so maybe I could put one under and one in? Maybe behind the seats? But someone said that is too hot as well. We'll see. Maybe on the backside of the strut up sideways on the wall? That would be pretty visible though. I've been searching and searching, people said they were going to do these things, but no later reviews...so I guess no ones overheated and died. Of course, I'll only be mounting a 360/2 and a 500/1 so maybe I won't have a hell of a lot of heat? I'm going to put the xovers in the doors, probably put the power block somewhere totally inaccessible under the glove. Anyone installed in one of these locations with something similar have feedback?
Old May 6, 2011 | 07:16 AM
v-rath's Avatar
v-rath
So, I went and got some liquid nails and some mdf. Lol screw the glove compartment, into storage it goes.
Old May 6, 2011 | 07:18 AM
2fasst's Avatar
2fasst
That SRQ box with sub is maybe 30 lbs? Is that pretty heavy considering it's only be held by one side? Was the install difficult for the same reasons?
Old May 7, 2011 | 07:01 AM
v-rath's Avatar
v-rath
the box is at max 5-10 lbs. not heavy at all. the sub is supposed to get here today, we'll see how heavy that is when I put it in.
Old May 8, 2011 | 04:27 PM
v-rath's Avatar
v-rath
Yes, the box with sub was very heavy. Install wasn't too bad, had to put matting on top, when the sub fired it was kicking the box up into the top of compartment. I did blow out a 60a fuse when I ran the bass test and turned it up almost all the way. I'm gonna go pick up an 80 from the audio shop tomorrow. Overall, it's loud, and has punch. I can't compare it to one hitting the back glass as I haven't heard one. But if it was any louder, I wouldn't like it, so that's enough for me.
Now to wait for my door pods and put in these new alpine spr-60c's in.
-BTW Thanks for all the advice and help.
Old May 10, 2011 | 09:22 AM
2fasst's Avatar
2fasst
I asked because i thought you had already installed it. Mine arrived the same time yours did and you're right, installation was NOT good. It didn't fit right and i had to file down certain areas of the wood for it to fit. Also, it's heavy! The bass is 'muffled' and does not hit has hard as my Zenclosure corner box I was running. But since I needed more trunk space, I may run this setup for a while
Old May 11, 2011 | 02:28 PM
v-rath's Avatar
v-rath
I noticed the muffling...and a LOT of rattle at high volume... the only thing I can think of is to put polyfill in the compartment around the sub, and to put it under the snap in plastic panels...anyone have a fix for this?
