Removal of dash with factory nav
Old Dec 6, 2003 | 09:51 PM
scubasteve's Avatar
scubasteve
Default Removal of dash with factory nav
How do I remove the center dash when I have the factory navigation system. I can't find anything in the forums about it. No one seems to have the factory nav!
Old Dec 7, 2003 | 06:39 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
I don't have it but doesn't the dash come out the same way?
In case you haven't seen/tried this (maybe you already have) take a look at Scafremon's how to on dash removal:
http://www.350zfrenzy.com/diy/center_console/index.php
I would guess you'd just have to unplug whatever plugs into the back of the Nav unit to remove the dash this way.
Old Dec 7, 2003 | 06:42 AM
onecoolee's Avatar
onecoolee
I have the factory nav... but, if the link Dr Bonz provided is not sufficient, PM me with your questions, I am sure that I can help. I can take the dash apart in my sleep now...
Old Dec 7, 2003 | 07:06 AM
grutter's Avatar
grutter
Default Re: Removal of dash with factory nav
The post is correct.. except when he refers to removing the rubber mat from the NAV compartment.. you'll have to pop out the NAV control panel. It'll just pop out, then unhook the harness connector.
Old Dec 7, 2003 | 08:59 AM
scubasteve's Avatar
scubasteve
I went to take the dash out, using the instructions on the forum, but all the dash removal forums are removal without the factory navigation. I can get as far as removing the panel around the shifter and popping the top of the dash out. I stopped when it grabbed around the NAV unit. I remembered seeing the two screws in those without NAV, but I couldn't get to them or see them. I would have been done by now!!!!!
Thanks,
Steven Krohn
Old Dec 8, 2003 | 01:37 AM
swoobyz's Avatar
swoobyz
Thanks,
Steven Krohn
There is little difference between the nav and non-nav console removal.
Just make sure you have removed all of the screws shown in scaf's instructions.
My guess is that you left in the two screws just below the nav keypad.
They are pictured in scaf's photos: Photo #9, "Remove the 2 screws that are now exposed."
Pv
Old Dec 8, 2003 | 06:39 AM
scubasteve's Avatar
scubasteve
That is exactly what happened. The problem is that when you have the factory nav, those two screws are hidden by the nav control panel. I was informed by onecoolee how to remove this panel first. After that, everything else is easy. Just a few adjustments to the wiring harness and installation of onecoolee's nav/aftermarket harness and I was done. I will post a thread detailing this installation later. I will show pictures of this installation with the nav unit and onecoolee's harness thing. Anyway, thanks for everyone's help. Now, I will install my Infinity components and rears. I think that I will have a custom box for two 10" behind the seats/ forward of of strut bar in that dead area.
Thanks Again,
Steven Krohn
sales@czp
Sep 23, 2019 03:30 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
