Scytek Astra 777
Old Jul 31, 2011 | 04:56 PM
harman850t5's Avatar
harman850t5
Default Scytek Astra 777
I've tried searching around here and on google, but haven't found much.
When I bought my car it already had the astra 777 installed but only came with the 5 button remote and not the lcd one, which I just found out it should have had too.
I've been thinking about tearing the whole system out and going back to the factory one (I received those remotes too), but would buying a replacement lcd pager be worth it? I can't even tell what the screen would display other than if it's armed or not.
Thanks for your help
Old Jul 31, 2011 | 05:04 PM
harman850t5
I found the owners manual online, think I may keep it. Pretty sure I have the remote start feature since it appears the factory clutch pedal switch connector is unplugged and a different harness plugs into it on my car.
Just gotta remember to keep it in Neutral if it does, was quite scary when I got a truck to randomly start at work while it was in reverse. Luckily I was able to tackle it and stall it before it hit something.
Also found out how to silently lock and unlock the car, and what I did to get the windows to roll up. Still can't get them to roll down with the remote though. But I think remotely rolling them up is more beneficial to me anyways. Such as surprise rain storms.
Old Aug 4, 2011 | 10:38 AM
KPierson_'s Avatar
KPierson_
If it does have a remote start in it it should have an interlock to prevent it from starting in gear. The car has an OEM P/NP switch that goes to ground when in N - this signal should be connected to a start inhibit on the unit.
georgyo
Jan 1, 2010 02:40 PM
alan86
Apr 14, 2007 05:55 PM
