Need help on Footwell lighting
Old Sep 20, 2011 | 06:24 PM
C-BANG's Avatar
C-BANG
Default Need help on Footwell lighting
I've been trying to find different ways to wire my led light to my z.
But i'm trying to find a way to install it by the driver side kick panel.
I try doing base on this:
i just hooked up 2 each 15" varad led tubes blue
tiestrapped under dash illuminating the entire footwell area in blue
can't see the led's just the accent lighting they produce
installed a switch under the dash for on and off
ran 12v power lead from fuse box by driver left kick panel to switch
ground from switch to left of steering column
hook up + wire leads from led's to load pin on switch
hooked up - wire leads from led's to ground swith pin
total time for install 1 hour taking your time
But it didnt work, so if anybody does know how to install this way, can you please send some pics plz. Thanks
Old Sep 20, 2011 | 06:26 PM
wrecker's Avatar
wrecker
neon lights on the feet and under the car ??? my lord
Old Sep 20, 2011 | 06:27 PM
jduet's Avatar
jduet
Is there a fuse in the position you chose?
Old Sep 20, 2011 | 06:32 PM
C-BANG's Avatar
C-BANG
yeah but it didn't work. and i ground the - wires to the left of the of the steering wheel column. still didn't work.
Old Sep 20, 2011 | 06:34 PM
wrecker's Avatar
wrecker
i believe there is a video tutorial in The Fast and the Furious
Old Sep 20, 2011 | 06:37 PM
C-BANG's Avatar
C-BANG
Do you have the link to that video or something like that. Would help alot.
Old Sep 20, 2011 | 06:38 PM
wrecker's Avatar
wrecker
honestly i would just tap off the red stereo wire behind the deck..
Old Sep 20, 2011 | 06:43 PM
jduet's Avatar
jduet
I'd check the fuse spot you used with a multimeter, it may not have power.
The other things I can think of are bad neons, bad switch/switch wired wrong, bad ground
I did this in my civic back in the day (not ment as an insult) and I just wired it directly into the 12v power thing (cigarette lighter). I tapped into both wires and ran that to the leds with a switch in the middle
Old Sep 20, 2011 | 06:44 PM
SuperBlack350z's Avatar
SuperBlack350z
white leds in the footwell actually looks pretty classy in the Z
Old Sep 20, 2011 | 06:50 PM
C-BANG's Avatar
C-BANG
Oh the led are still good, but i havent checked if the power that i ran that wire to even had power coming out of it. But ill have to check on that.
Think taping it to the stereo is better?
Old Sep 20, 2011 | 06:54 PM
jduet's Avatar
jduet
I'm by no means an electrical expert but I think that might rob power from your stereo, somebody else may be able to chime in on that.
There is always the power port under the passanger dash that you can tap into
Old Sep 20, 2011 | 06:55 PM
C-BANG's Avatar
C-BANG
I got a red z, and on my b day they bought me some red led so i figured it match with my car. But white would be nice too.
Old Sep 20, 2011 | 06:58 PM
C-BANG's Avatar
C-BANG
yeah your right on that, yeah so maybe the best way is to install through the fuses box huh?
Old Sep 20, 2011 | 08:46 PM
R350Zz33's Avatar
R350Zz33
heres what you do take your key and use it to pop out your map light figure out that wire is the negative and positive tap into them run wires down to the foot well and hook up ur led's that way they will now come on when the door opens your welcome. i know this works because ive done it my last project was 50+ led's on a board in the trunk so i can see when i open it at night
Old Sep 21, 2011 | 12:43 AM
dcains's Avatar
dcains
That's what I did in my '08. The footwell LED's are on/off with the doors, but each side also works independently from the other when each overhead light is switched on/off. They even slowly fade off when the doors close, so they look like a factory install.
Here's one of the LED strips I used:
Here's the wiring from the overhead console:
Passenger footwell (wiring to other side not finished yet):
Driver's side (looks brighter from the reflections off the pedals):
Old Sep 21, 2011 | 06:48 AM
OkashiZ's Avatar
OkashiZ
^ I like that. I just found my next diy project
Old Sep 21, 2011 | 09:13 AM
zakmartin's Avatar
zakmartin
Wow... you spend all that time being a d-bag and then you offer your sage technical advice, which is bad advice, by the way. Way to go!
Old Sep 21, 2011 | 10:03 AM
R350Zz33's Avatar
R350Zz33
That's the only way to do it right and make it fade like that you don't need to have it on while driving that's just another distraction
Old Sep 21, 2011 | 11:06 AM
wrecker's Avatar
wrecker
cman.. u know there is a tutorial in The Fast And The Furious Movie..
Old Sep 21, 2011 | 12:22 PM
KPierson_'s Avatar
KPierson_
The only way you will fix this problem correctly is with a volt meter. You need to find an ignition wire (only hot when key is in the "ON" position). If you don't have a volt meter then I would look in to tapping the auxiliary power outlet as mentioned above. It should be fairly easy to get to and it has 15A of switched power.
Connecting the LEDs to the power wire of the stereo will NOT steal power from the stereo. There is ample current supply on that wire, but I wouldn't do it simply for the fact I wouldn't want to pull the radio out and have to figure out exactly which wire is the correct wire (on an aftermarket radio it would be the red wire, but on the OEM radio there is no guarantee the wire is red). The auxiliary plug is easy - it only has two wires going to it!
