Need help on Footwell lighting
Old Sep 21, 2011 | 06:32 PM
C-BANG's Avatar
C-BANG
Okay so i got my power wire running from my fuse box, the wire is in the place with the (cigarette lighter) fuse. Now i got my ground running on the left side of the steering wheel column and taped with the led light. And i have the other led light hook to the switch i have.
Now about the switch i have, There's three label that are on it.
15A-12V-DC i don't have a clue what wires goes where, but the 12V i know.
but the other two idk.
So do yall have any suggestions or anything? wanna get it hooked up before XDC that there having here in Texas.
Thanks in advances.
Old Sep 21, 2011 | 06:44 PM
KPierson_'s Avatar
KPierson_
The label on the switch means it has a current max of 15A, is rated for 12 volts of DC. Those are not pin labels!
How many pins are on the switch? Is there a diagram of the switch on the package the switch came in? does the switch have a light in it?
What happens if you take the switch out and just connect the two wires going to the switch together?
Old Sep 21, 2011 | 08:44 PM
C-BANG's Avatar
C-BANG
I have three pin, nope there's no diagram for it, I found it laying around my garage. Yes the switch has a light inside of it.
I've never really tired it. Basically I had three wires going to the switch, I had the power wire, ground wire w/ led and the other one on the switch. Is there something messing that I'm forgetting? Bc I did it that way, the switch turned on and my leds didn't.
Old Sep 22, 2011 | 02:45 AM
KPierson_'s Avatar
KPierson_
I would bypass the switch next and see if the LEDs come on that way.
Where is your ground connected to the vehicle at? Did you connect the ground pin of the switch to the same spot that you connected the ground on the LEDs?
Old Sep 22, 2011 | 01:28 PM
C-BANG's Avatar
C-BANG
The ground is connected to the left of the steering.wheel column.
No I didn't, was I suppose to?
Old Sep 22, 2011 | 02:00 PM
KPierson_'s Avatar
KPierson_
It's not necessary to, I was just confused by how you said you had it wired up above. It kind of sounded like you wired the ground of the LED to the ground pin of the switch. Just wanted to make sure that wasn't what you did.
Old Sep 22, 2011 | 03:04 PM
C-BANG's Avatar
C-BANG
sorry about that, but after you told me just taped it directly to the leds without the switchs. It worked perfectly fine now. thanks for the help.
Old Sep 22, 2011 | 03:06 PM
zakmartin's Avatar
zakmartin
Can you provide a photo of the switch (front and back) so we can see what you're working with? Also, where you tapped into the fuse box, are you sure that your power (red) wire was tapped in to the positive side of the fuse? If you use a digital multimeter, does it read 12V instead of -12V on the positive wire?
Old Sep 22, 2011 | 04:02 PM
C-BANG's Avatar
C-BANG
Thanks for the help, i got the lights hooked up already. i tapped my power wire to the fuse box (cigarette lighter fuse) and my ground to the left of my steering wheel column.
Old Sep 22, 2011 | 04:04 PM
KPierson_'s Avatar
KPierson_
Both sides of the fuse are hot. It is important to find the load side of the fuse or to add your own fuse to protect the wire you are adding. The easiest way to find the load side is to pull the fuse out and measure voltage at each empty prong. The prong that still has 12vdc is the line side, the other prong that has no voltage on it is the load side.
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
