sub and amp help
Old Jan 25, 2012 | 10:00 PM
R350Zz33's Avatar
R350Zz33
Default sub and amp help
i have everything in place just need help with sub and amp wiring and choices
ill be using 2 alpine type r 10".
now the first choice dual 2 ohm or dual 4 ohm
2 ohm specs:
10" Dual 2 Ohm Type-R Series Subwoofer
Power Handling:
Peak: 1500 watts
RMS: 500 watts
Impedance: Dual 2 ohms
Kevlar reinforced pulp cone
4 ohm specs:
* 10" subwoofer with dual 4-ohm voice coils
* Kevlar reinforced pulp cone with Santoprene rubber surround
* cast aluminum frame with perimeter venting and radial finned heat sink
* frequency response: 24-500 Hz
* power handling: 300-600 watts RMS (300 watts per coil)
1800 peak
ok so i will eaither be getting TWO 4 ohm or TWO 2ohm subs
now on to the amp:
Features:
Chaos Epic Series Class D Monoblock Power Amplifierr
MOSFET power supply
LED power and protect indicators
Variable Bass Boost (0-18 dB)
Soft Start Turn-on
2-Channel operation
Remote turn on/off circuit
Tri mode capable
Remote Subwoofer level control
Variable input gain control
Speaker-level (high-level) inputs with signal sensing for automatic turn-on
2-Way System Protection circuitry (thermal and speaker short protection)
Heavy duty black anodized aluminum heatsink for extreme heat dissipation
Strapping capability: Strap two Amps together for twice the power
Nickel-plated RCA level inputs
Nickel-plated screw terminals
Variable low-pass filter
1/0-gauge power and ground wiring is required for installation
Specifications:
RMS Power Handling:
4 ohms: 800 watts x 1 channel
2 ohms: 1200 watts x 1 channel
Peak Power Handling:
2 ohms: 1800 watts x 1 channel
1 ohms: 2800 watts x 1 channel
Variable Low-Pass Filter: 50-150 Hz
Subsonic Filter: 15-40 Hz
Frequency Response: 50-150 Hz
Signal-to-Noise Ratio: > 100 dB
Input Sensitivity: selectable 100mV-2V or 2V-8V
Channel Separation: 90 dB
Phase Shift: Selectable 0/180°
THD (Total Harmonic Distortion): 0.01%
Dimensions(L x W x H): 12-3/4" x 11-7/8" x 2-3/4"
i think if i get the subs to run 2 ohms together then i would get the 1200w rms needed is that right is can i do that and how would i wire them ?
Old Jan 25, 2012 | 10:44 PM
R350Zz33's Avatar
R350Zz33
found this http://a248.e.akamai.net/pix.crutchf...no-low-imp.jpg so i need a 1ohm load cant get to 2 from 2 dvc 4ohm subs thinking about this amp.
Features:
XT2000DE V3 1,200 watt RMS (2000w peak) mono car amplifier
Class "D" fully digital power supply
2000 watts peak output
1,200w x 1 RMS @ 1 ohms
750w x 1 RMS @ 2 ohms
500w x 1 RMS @ 4 ohms
Bridgeable
Efficiency: 86 % @ 4 Ohms or 84 % @ 2 Ohms or 76 % @ 1 ohm
Fully adjustable butterworth low pass crossover filter
Low Pass Crossover Filter - Adjustable 40 - 250 HZ @ 24 dB per octave
Adjustable Bass Equalizer: 24 dB Bass Boost @ 45 HZ
Subsonic Filter: 15-40 HZ @ 24 dB per octave
Low level Input
RCA Pre-amp output
Pass through output for multiple amp installs
Block Power Connector
Requires true 0 gauge power wire for installation ( already have this )
Screw terminal barrier strip speaker connectors
8 - 18 AWG speaker connector gauge
Aluminum heatsink
Convention cooling
power and protection LED Indicators
Class D
Frequency Response: 20 HZ - 500 HZ
Thermal, Overload, Short circuit, DC Offset protection
Fuse Rating: 75A (3x25A fuses)
Damping Factor: 150
Low Input Impedance: 22 Ohm
Input sensitivity: 200/8.0
Free bass Remote Included
S/N Ratio: 80 dB
Weight: 13 pounds
Dimensions: 1.875" x 10" x 13.33"
Old Jan 26, 2012 | 08:57 AM
JMII's Avatar
JMII
Is this a question or a statement? It looks like you figured out which ohm speakers you need to achieve the best ohm load for the amp, so you are good to go! Just remember the power will be divided equally between the two speakers: 1,500 / 2 = 750 per sub.
Old Jan 26, 2012 | 10:21 AM
R350Zz33's Avatar
R350Zz33
I just want someone to say yes that will work just wanna make sure I think option 2 2nd post will work not the one in the first one
Old Jan 26, 2012 | 12:20 PM
JMII's Avatar
JMII
Yes two 4 ohm DVC subs wired in parallel = 1 ohm. Two 2 ohms DVC subs can't be wired to 1 ohm, only .5, 2 or 8 ohms. All sorts of calculators here: http://www.bcae1.com/spkrmlti.htm
Old Jan 26, 2012 | 01:36 PM
R350Zz33's Avatar
R350Zz33
Ok cool so I should go with 2 4ohm dvc and amp in 2nd post ?
Old Jan 26, 2012 | 02:53 PM
DBTre50z's Avatar
DBTre50z
Yes, if you go with the D4 subs, then you will be able to wire it to 1 ohm. If you go with D2 subs then you will be able to wire them to 2 ohms. Becuase those subs are good for 500~ watts rms any amp 1000-1200 watts will be fine. The 1000-1200 watts will need to be @ 1 ohm if your running the D4 subs or your amp will need to make 1000-1200 @ 2 ohms if you run the D2 subs. Have you seen my set up yet? I went from the single 12 to 2 8's
Old Jan 26, 2012 | 03:18 PM
R350Zz33's Avatar
R350Zz33
Probly I've been looking over lots of builds you went with two 8s for better sound quality right
Old Jan 26, 2012 | 03:34 PM
DBTre50z's Avatar
DBTre50z
I went with sundown audio SA8s because ive seen a few videos on them and some members on here swear by sundown. I was getting bored of my set up and the box i had was so big and ghetto, i built my own box for underneath the strut bar and im very happy i did.
Old Jan 26, 2012 | 04:20 PM
R350Zz33's Avatar
R350Zz33
I'm just doing your basic budget build that anyone can do with accese to already made stuff I started a thread in the audio build but stuff is taking so long with shipping. I'm hoping to record most of the build in 1280p to help the more visual learners where sometimes the pix on builds are alil vague the video can fill in
Old Jan 27, 2012 | 05:28 AM
JMII's Avatar
JMII
With the right box and the right power two 8"s compare nicely to one 12" ...easier to find room for the 8"s too.
m_0g
Jun 3, 2021 10:05 AM
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
cashmoney03
Sep 27, 2015 05:24 PM
Shane86
Sep 17, 2015 05:33 PM
