speed pulse generator location?
Old Jan 5, 2004 | 03:00 AM
mikeef's Avatar
mikeef
Default speed pulse generator location?
Does anyone know where the speed pulse generator is located?
Old Jan 6, 2004 | 08:13 AM
themyst's Avatar
themyst
when you remove the center console, there is a white box. in the white box, there is a white wire. cut and splice the speed sensor wire (assuming pioneer headunit) into that white wire.
Old Jan 8, 2004 | 11:36 AM
isaaktnt's Avatar
isaaktnt
Default How can you tell?
I had it installed by a shop but not sure they connected it. How can I tell? When I go to info and connection status the pulse reading is always zero. When i go to the 3D status then the speed there works but I am not sure that they connected it correctly. I have AVH-P6500 plus the AIC-80? model.
Thanks
Old Jan 8, 2004 | 11:50 AM
mikeef's Avatar
mikeef
They haven't connected it; if they had, the pulse reading should go up when you are drving.
Old Jan 8, 2004 | 01:32 PM
themyst's Avatar
themyst
Default Re: How can you tell?
Thanks
yeah they didn't connect the speed sensor. Its not that big of a deal to be without the speed sensor regardless... the positioning of the GPS by itself is more than sufficient. I didn't connect the speed sensor for a while, and I didn't notice any real improvement after it was done.
Old Jan 8, 2004 | 01:50 PM
mikeef's Avatar
mikeef
I think it is somewhere different in UK cars, but no-onein the UK seems to know where!
Old Jul 10, 2005 | 02:48 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
There are no white wires into my white box - there is a white wire with gray bands and another white wire with a black line down the lenght of it.
Old Aug 7, 2005 | 08:52 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
OK to confim the speed pluse wire is the white wire with light gray loops every inch and a half coming from the center connector of the unified meter and AC amp.
Old Feb 6, 2006 | 02:36 PM
FirstZ's Avatar
FirstZ
Paul,
I used your instructions today. I was able to find the speed pulse wire w/ ease and my AVN works perfect!
Thank you,
Rob
Old Jul 15, 2006 | 02:09 PM
Nforce1's Avatar
Nforce1
Originally Posted by FirstZ
Paul,
Thank you,
Rob
What did u use to tap into the wire?? or did you splice it?? im trying to aviod having to cut the wire.
If I dont tap into the speed sensor wire, will the voice navigation not work?? Im having some issues with that. I have the voice setting at "7" but no voice directions are ever made. Is it because I didnt tap the speed sensor wire??
Old Jul 15, 2006 | 03:32 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Use a 3M splicer available at any PepBoys or the like. They slide over the target wire and then you insert the wire you wish to join to the target. Then you use a pair of pliers to crimp a metal fixture into place and then close a plastic cover over the top to seal the connection. You'll want the red color one for that gauge wire.
Old Jul 15, 2006 | 04:01 PM
Kirkster's Avatar
Kirkster
That is correct... No speed sensor no voice guidance...
Old Jul 15, 2006 | 11:13 PM
Nforce1's Avatar
Nforce1
That would explain that!
Old Jul 16, 2006 | 04:19 PM
Nforce1's Avatar
Nforce1
I tried to do this.. but for some reason, it still didnt sence the speed sensor wire?? the unit still says "check speed pulse."
Old Jul 16, 2006 | 09:31 PM
leemik's Avatar
leemik
I took a crappy pic of this wire recently:
Old Jul 17, 2006 | 01:26 AM
Nforce1's Avatar
Nforce1
Yeah, thats the wire I clamped to... maybe it just wasnt a good enough clamp??
Old Nov 17, 2006 | 05:43 PM
Questhate's Avatar
Questhate
So did you figure this out? I'm installing an AVIC-Z1 into my car this weekend and don't know **** about electrical wires and whatnot. My dad is helping me with the install, and he's an electric technician, but he's not familiar with the specifics of my car. So the Speed Pulse Wire (white with gray loops) is the only wire that needs to be clamped, right? Any other wires need to be spliced? What's the red gauge wire that Paul was talking about a few posts up?
I wish there was an install manual online specifically for this deck in this car. I have an install manual from crutchfield which shows directions on installing any generic double din head unit into my car, as well as instructions on installing the DVD-based navigation system (specifically, the AVIC-D2 or AVIC-N1, I think), but not the Z1. If someone could point me to some useful resources, that would be very kind of you.
Stevo Z
Oct 3, 2015 09:14 PM
Tochigi_236
Sep 27, 2015 03:40 PM
