A/C and Speaker problems
Old Sep 16, 2012 | 08:50 PM
aznxdope's Avatar
aznxdope
Unhappy A/C and Speaker problems
Hi all, I have a 2006 base with 47k miles. I've noticed that my air conditioning only works sometimes (randomly). I turn the AC button, the light turns on, but nothing blows out of it, not even hot air. In addition my rear speakers only work sometimes, its a hit and miss for both. Anyone have any thoughts of what I should check?!? I'm no good with wiring and taking things apart. Please help!!! BTW, I purchased the car with a Pioneer avic-Z1 which may have something to do with it. THANKS!
Old Sep 16, 2012 | 10:21 PM
OkashiZ's Avatar
OkashiZ
Check for blown fuses
Old Sep 17, 2012 | 03:55 AM
BipJip's Avatar
BipJip
check your connections for your radio. if the previous owner cut and spliced into the factory harness you could have a bad connection causing a problem. i recomend soldering and shrink wrap all cut connections.
Old Sep 17, 2012 | 05:16 AM
122554's Avatar
122554
Sounds like bas connection on the ac controller and the ribbon cable.
Old Sep 17, 2012 | 12:47 PM
beezee's Avatar
beezee
Op said it works sometimes. Most likely not a blown fuse
Uriyo_
Sep 8, 2021 08:46 AM
