Wiring harness
Old Feb 19, 2013 | 03:44 PM
JuarezErick's Avatar
JuarezErick
Default Wiring harness
Does the Z with the Bose system and navigation
Use the same wiring harness as the one with
Non-navigation
Old Feb 19, 2013 | 04:06 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
be more specific.
if you are trying to install nav into a non nav car, that harness and a whole bunch else is missing
Old Feb 19, 2013 | 04:12 PM
JuarezErick
No my car has nav bt my new stereo is a regular single din
Head unit
Old Feb 19, 2013 | 04:26 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
so you are looking for the patch harness to adapt your oem harness to your new stereo?
Old Feb 19, 2013 | 04:34 PM
JuarezErick
Yes I got one bt when I hooked it up no sound came out that's why
I'm wondering if there are different
Old Feb 20, 2013 | 07:39 AM
bender's Avatar
bender
Non-navigation
If you have a Bose system and you're only replacing the deck, you'll want to use a PAC ROEM-NIS2 harness. You're bound to have issues without one as the deck will sometimes have issues with the factory Bose amp.
The harnesses are the same between models i believe. You'll have one harness plug from the car left over from the factory navigation voice. You'd just leave that unplugged. Save yourself from possible headaches and buy the PAC ROEM-NIS2 and do it right the first time.
That being said, you still will usually get sound without one. The sound volume is where the issues arise. It sounds like you've blown a fuse.
350Z_Al
Oct 29, 2020 07:44 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
nanotech
Oct 2, 2015 05:02 AM
cashmoney03
Sep 27, 2015 05:24 PM
