Installing a new deck
Old Mar 6, 2013 | 08:21 AM
krazy k's Avatar
krazy k
Default Installing a new deck
Hi Everyone,
I already have a single din aftermarket radio. I want to upgrade it with a better one. Do I need a new wiring harness? Does anyone have an installation guide?
Thanks.
Old Mar 6, 2013 | 09:31 AM
shadowm891's Avatar
shadowm891
not sure what year your 350z is but here is a good one off youtube
h**p://www.youtube.com/watch?v=PnpBHdqnj0k
Old Mar 6, 2013 | 08:22 PM
Collin Lacy's Avatar
Collin Lacy
Provided the original installer didn't butcher everything, no you don't need a new wiring harness.
Generally when someone says wiring harness they are talking about the one that connects to the original plug to your bose head unit, and then has a bunch of labeled wires that you connect your new head unit to. All you have to do is take out the old head unit, cut the wires where they are crimped or soldered together, and reconnect to the new head unit.
Old Mar 25, 2013 | 09:29 PM
hooahh3's Avatar
hooahh3
do they make a plug and play harness for it. one that plugs into the stock harness in dash and then back of your aftermarket HU? that would save so much time and hassle in an install.
Old Mar 26, 2013 | 07:13 AM
K51's Avatar
K51
That would be a problem, as each head unit has a different sort of plug, often even within the same brand, so there would have to be countless adapter configurations made available. Buy a head unit, buy the appropriate adapter harness (to match the car), and do all the connections between the adapter and head unit on your dining room table. There may be a few extraneous connections you still have to make while plugging the adapter/had unit onto the car's harness, such as an amp turn-on lead, antenna amp, etc.
Old Mar 27, 2013 | 12:36 PM
DarkCreep's Avatar
DarkCreep
No, that would be far too expensive to make since they would need to make them for each radio and each car.
All the cables are usually the same for each aftermarket radio. Just match the colors and connect power and ground.
3vilbunny
Jul 18, 2017 05:10 PM
