Only one speaker works after install.
Old Mar 30, 2013 | 04:16 PM
TradosKicks's Avatar
TradosKicks
Default Only one speaker works after install.
After installing an aftermarket hu only the right rear speaker is working. Before screwing everything back together I tested the head unit and everything worked. 30 minutes later i turn my car on and only the RR is working. All the wires are connected properly so I don't get it. Any help is appreciated.
Old Mar 30, 2013 | 10:47 PM
NismoDude's Avatar
NismoDude
maybe when you were putting back together your center console you pulled/tugged the wires or they got caught/snagged and became disconnected.
did you solder your connections and tape them? or just twist together and tape? or crimp connect them?
I only suggest this because after replacing my headunit twice in the last month, I found the hardest part was putting everything back together, especially with extra wiring behind the headunit, as space is VERY tight. I had 2 sets of RCA leads to my amp, and other wiring for a remote radar detector and USB cable, along with the radio wiring harness, cable to backup camera, etc, and I had a ***** of a time getting it all into place and replacing the front center console.
Old Mar 31, 2013 | 05:05 AM
TradosKicks
Yeah Im planning on taking it back apart today and checking the connections again. As far as connecting the wires, I crimped them. Thanks.
3vilbunny
Jul 18, 2017 05:10 PM
_bit
Oct 2, 2015 07:49 AM
