Window speaker magnet problems?
Old Jan 31, 2004 | 12:55 PM
liptonme's Avatar
liptonme
Unhappy Window speaker magnet problems?
Has anyone had problems with the roll down feature after you've added after market speakers. I got the focal polyglass v2 and I just started noticing that the windows don't roll down properly when the door opens and closes. Or is this a problem with everybody's car. I would appreciate some opinions... I posted this in the repair forum but no one responded....
BTW, where is 350speedracr...????
Old Jan 31, 2004 | 01:00 PM
bastard's Avatar
bastard
If you disconnected the battery, you have to play with the windows a little bit so they learn where fully up is again. Mine did it too. Try closing the door and rolling both windows all the way to the top. It should work then.
Old Feb 2, 2004 | 11:33 AM
liptonme's Avatar
liptonme
well.... This is what happens, when the door is opened the rear of the window seems to go down first and the front kinda follows behind (sticks), and it does not go down as far as it used to. Had the audio installer look at it. He couldn't figure it out. I also had the TSB window grease done too, could this be part of the problem? Thanks for you reply "bastard"
Old Feb 2, 2004 | 12:58 PM
MacAlert01's Avatar
MacAlert01
Did you install spacers for the speakers? If not, when fully opened, the window might be hitting the speaker causing the front of the window to stick up or throw the window off balance.
Old Feb 3, 2004 | 06:39 AM
liptonme's Avatar
liptonme
the installer used the original spacers that were on the factory speakers...
Old Feb 3, 2004 | 11:26 AM
bastard's Avatar
bastard
If it's your speakers causing the problem, then it wouldn't have an effect until the last like 3-4 inches of the window's travel (at the bottom). If the window's doing this weirdness at the top of its travel on the way down (that's what it sounds like from your description), then I would think that it would have to do with the grease streak repair TSB.
Old Feb 3, 2004 | 01:28 PM
liptonme's Avatar
liptonme
has anyone else had this problem after this Grease streak TSB..?
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
