thump sound from my sub
Old Feb 26, 2014 | 11:00 AM
Whiteazn2's Avatar
Whiteazn2
Default thump sound from my sub
I did research on what the cause of the thumping sound coming from the sub, and all I saw was that check my ground wire but that's fine.
When I turn my car on my sub makes a heartbeat or thump sound. The amp (kenwood) light blinks when it thumps. Any idea what the problem is? I have a kicker sub and I checked the indash but there was no loose wire and also checked amp fuse, so any ideas?
Old Feb 26, 2014 | 11:09 AM
jhc's Avatar
jhc
General & Tech Moderator
It's only when you first power-up, right? Every remote amp I've had did the same thing on start-up. Is it different from before?
Old Feb 26, 2014 | 11:24 AM
Whiteazn2's Avatar
Whiteazn2
It stays on when I turn the car on. It's never did it before, and also the sub doesn't bump of course when music is on.
Anyways update I looked at my sub when I turn it on and I saw little smoke coming out from it. So I took the sub apart and it's smoking a little so that's probably the cause. So you think I need new subs or can fix it?
Old Feb 26, 2014 | 11:35 AM
07maximan's Avatar
07maximan
Just replace it. Kicker stuff can be had for cheap.
Old Feb 26, 2014 | 11:56 AM
jhc's Avatar
jhc
So, dumb q's-
1) correct wire gauge,yes? High out and small wire=high resistance, heat.
2) impedance from amp matches rating on sub?
Old Feb 26, 2014 | 12:04 PM
Whiteazn2's Avatar
Whiteazn2
Yes I had both subs and amp, wires for over 4yrs
Old Feb 26, 2014 | 12:09 PM
92K1500's Avatar
92K1500
Generally people are asking about a thump on turn off.
What model kicker? How many subs? What model amp?
Smoking means the coil got hot. Doesn't mean anything is broken though.
What are your gains set to? Don't give me physical settings, I want voltages.
Old Feb 26, 2014 | 12:59 PM
Whiteazn2's Avatar
Whiteazn2
Kenwood model Kac8103d
Kicker sub 07cvt124
I have one sub and all the places I call don't fix them.
Old Feb 26, 2014 | 01:08 PM
92K1500's Avatar
92K1500
kachina is not a kenwood model number....
Old Feb 26, 2014 | 01:10 PM
Whiteazn2's Avatar
Whiteazn2
Sry stupid phone corrected it but I edit it
Old Feb 26, 2014 | 01:12 PM
Whiteazn2's Avatar
Whiteazn2
Also kenwood is 1000 watt amp and the sub is 4ohms
Old Feb 26, 2014 | 01:25 PM
92K1500's Avatar
92K1500
The Kenwood is actually 300W at 14.4V, so anything lower than that and you have even less power.
That sub is rated 400W.
My guess is the bass boost and gains are cranked way up to get output from it and you've mostly cooked the sub. I've seen it many times.
The Z is also wonderful at masking distortion from the sub.
Old Feb 26, 2014 | 01:26 PM
92K1500's Avatar
92K1500
So what is the gain set at?
Old Feb 26, 2014 | 01:36 PM
Whiteazn2's Avatar
Whiteazn2
The amp is 1000 watt I looked it up and I need to check what it's set at
Old Feb 26, 2014 | 01:50 PM
Whiteazn2's Avatar
Whiteazn2
It's not up to high
File Type: jpg
Old Feb 26, 2014 | 01:54 PM
92K1500's Avatar
92K1500
Uh, according to Kenwood it's a 300W amp.
http://my.kenwood.com/Car_Entertainm...iers/KAC-8103D
Rated Power Output [14.4V]
• 300W x 1 at 4ohms [20-200kHz 0.5% THD]
Old Feb 26, 2014 | 01:55 PM
Whiteazn2's Avatar
Whiteazn2
http:// Name:  20140226_144324_zpse1ac9116.jpg
File Type: jpg
Old Feb 26, 2014 | 01:58 PM
Whiteazn2's Avatar
Whiteazn2
Max power is 1000 watt
Old Feb 26, 2014 | 02:00 PM
Whiteazn2's Avatar
Whiteazn2
So another words need another sub?
Old Feb 26, 2014 | 02:16 PM
92K1500's Avatar
92K1500
That picture doesn't tell me anything. I don't know where the **** is when it's rotated all the way counter clockwise and I don't know the line voltage on your preout.
Physical position of the **** means nothing. Output voltage tells you where to set it.
Also, max power means nothing to anybody. RMS is the only thing to look at.
