Problems with installation of kenwood DDX4025BT
Old May 7, 2014 | 06:28 AM
Basse_hamer's Avatar
Basse_hamer
Default Problems with installation of kenwood DDX4025BT
Hi!
I tried to install my new kenwood DDX4025BT in my 03 350z (europen model). I got this harness (http://www.autokatalogen.se/afw/kris...deIdNo=1742890) and installed everything. But I cant get any sound from the speakers but everything else works as it should. The only wire I haven't connected is the black ground wire. Where should i ground it?
Any suggestions? Do I have to buy a PAC-ROEM NIS2 to get the speakers to work and if so, do they work on european models?
Very thankfull for a answer!
// Basse
Old May 7, 2014 | 08:08 AM
dcains's Avatar
dcains
Attach the ground wire to any screw under the dash which screws into the metal of the chassis. There are many to choose from.
Old May 7, 2014 | 08:56 AM
Basse_hamer
So I did but it still doesn't make any sound...
Old May 7, 2014 | 09:59 AM
Basse_hamer
So I took another look at it... There are many on the internet saying that you'd have to splice the AMP wire with the blue wire but I dont have a wire which says AMP, there is already a wire connected to the blue one. I just have 3 wires left: A brown one that says MUTE on it, a blue/white that says P CONT and ANT CONT and a blue/yellow wire that says STEERING WHEEL REMOTE INPUT.
Do i have to hook up any of these wires? If so to what?
Attached Thumbnails Problems with installation of kenwood DDX4025BT-img_0029.jpg
Uriyo_
Sep 8, 2021 08:46 AM
