Alternative to 06-08 navigation control switch?
Old Nov 10, 2014 | 11:15 AM
rbatakji's Avatar
rbatakji
Default Alternative to 06-08 navigation control switch?
I bought the 07-08 navigation waterfall. (has no cubby)
https://conceptzperformance.com/Cart...n.php?II=10968
I currently have a hole where the top screen is going to go and also where the navigation control switch goes. I am not going to be using the OEM navigation so the controls would be pretty much just for looks.
Here are the controls: https://conceptzperformance.com/Cart...on.php?II=5117
I've seen people have put plain plastic finisher pieces in place of the navigation controls. I can't find where to purchase this piece anywhere. If anyone can point me in the right direction that would be great. Thanks!
Old Nov 10, 2014 | 04:04 PM
rbatakji's Avatar
rbatakji
Anyone have any ideas?
Old Nov 10, 2014 | 05:39 PM
Spike100's Avatar
Spike100
[...] I've seen people have put plain plastic finisher pieces in place of the navigation controls. I can't find where to purchase this piece anywhere. If anyone can point me in the right direction that would be great. Thanks!
Where did you see: " I've seen people have put plain plastic finisher pieces in place of the navigation controls."
Old Nov 10, 2014 | 09:02 PM
rbatakji's Avatar
rbatakji
Hmm I guess all the ones I've seen are the 03-05 nav set ups. I guess I'll be stuck having to buy the oem nav controls.
Old Nov 10, 2014 | 11:26 PM
amr_electron's Avatar
amr_electron
The 03-05 ones will fit, But will not sit flush. And to get the OEM look, You will need the control switch & the finisher piece.
Old Nov 11, 2014 | 12:13 AM
rbatakji's Avatar
rbatakji
Do you mean the 03-05 black plastic finisher will fit or are you referring to the 03-05 nav control switch?
Old Nov 11, 2014 | 10:35 AM
amr_electron
Not my pic, But just to give you an idea of how the 03-05 nav switches will look like in a 06-08 nav bezel.
Old Nov 11, 2014 | 02:02 PM
kham25's Avatar
kham25
Check out page 6. Saved myself couple bucks...
https://my350z.com/forum/audio-and-v...n-cubby-6.html
Old Nov 11, 2014 | 02:39 PM
rbatakji's Avatar
rbatakji
Wow that would be perfect! What part is that? And is it secured in anyway or just sitting there?
Thanks.
Old Nov 11, 2014 | 06:19 PM
kham25's Avatar
kham25
Thanks.
Black silicone and flat piece of plastic I found in garage believe it or not. It's glued permanently. I smooth out the edges by using a dremel. It took a while cutting and fitting but came out ok...
Old Nov 11, 2014 | 09:23 PM
rbatakji's Avatar
rbatakji
Thanks for posting this! I'm probably going to buy a flat black plastic sheet online and just cut to size. I don't know why I never thought about that.
Old Jan 11, 2015 | 12:09 AM
DarkZ03's Avatar
DarkZ03
I made my panel out of a cubby door from the 06+ models, has the same color/finish as stock dash and the curve right on top of the radio matches perfectly.
Attached Thumbnails Alternative to 06-08 navigation control switch?-100_0063.jpg
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
Tochigi_236
Sep 27, 2015 03:40 PM
