front speaker recommendations....?
Old Feb 13, 2004 | 02:38 PM
dgtlbullet's Avatar
dgtlbullet
Awsome feedback man. I think i am going with the K's. I have found them as low as around $315. I plan on running around 150 X 2 so poer shouldn't be a problem.
Old Feb 13, 2004 | 02:46 PM
imntcrzy's Avatar
imntcrzy
should sound frickin nice!!!
Old Feb 14, 2004 | 07:21 PM
rodH's Avatar
rodH
I'd go Focals. (actually I did). I tend to favor home speaker manufactures since they aren't into as many gimmicks and are all about REAL sound. Focal makes over $100k home speakers and Dynaudio makes very good home gear as well, sure enough, when I listen to these car speakers, I liked them the most, Focals are great for the $$.
Old Feb 14, 2004 | 07:23 PM
rodH's Avatar
rodH
btw, the auditioning I did, I could tell a big diff between the 165 and the Polyglass, I'd go with the polyglass If I were you. The PolyK will be redesigned very soon, the polyglass were recently redesigned using a lot of the utopia technology.
Old Feb 16, 2004 | 05:54 AM
dgtlbullet's Avatar
dgtlbullet
Will the 165k2's or 3's fit wihtout the spacers and would my installer have a tougher time installing these versus one that doesn't need them. Any loss in quality with spacers? Thanks guys.
Old Feb 16, 2004 | 10:59 PM
jreiter's Avatar
jreiter
I can't comment on whether or not they'll fit without spacers, but I can say that you *shouldn't* have any quality loss when using spacers as long as the spacers are well designed. Make sure they provide a good seal between the speaker and door panel. A custom made simple wooden ring makes a good spacer, and should be easy for any shop to do.
On that note, I'm guessing you'll need a spacer for most aftermarket speakers, as they tend to have deeper mounting depths than cheap factory speakers. I haven't actually opened up the 350Z's doors to see how much room is behind the speaker hole, but I'm guessing it's not not a lot. A spacer should be easy, though.
Old Feb 17, 2004 | 06:16 AM
dgtlbullet's Avatar
dgtlbullet
Thanks for the info guys. I am still a newbie to all audio stuff and am not familiar with installation at all. I appreciate your help. Can't wait to get this system in. The system by far is my biggest problem with this car but hopefully it will be fixed very soon. I'll let you guys know how it comes out.
Old Feb 17, 2004 | 09:32 AM
imntcrzy's Avatar
imntcrzy
When I installed my focals the problem was the driver was hitting the window. I'm pretty sure you will need the spacer to clear the window.
Old Feb 17, 2004 | 05:11 PM
BoostTed's Avatar
BoostTed
3rd on the Diamond audio Hex's i loved mine when i had them...This time around i'll be running the 3-way Focal Utopia setup on the Z.
Old Feb 17, 2004 | 07:42 PM
ssk0771's Avatar
ssk0771
Do you have to install after market amp with these speakers or can you just use the BOSE system?
Old Feb 17, 2004 | 08:05 PM
jreiter's Avatar
jreiter
As with most Bose systems, if you plan to go aftermarket you pretty much have to go all the way. The amps they use are usually not good quality, are very low power, and are only marginally better than the awful amps inside of head units.
Additionally, BOSE systems often include some complex wiring from driver to driver, resulting in some odd impedences. Their amps are designed to handle these odd configurations, but if you start putting in aftermarket drivers with standard 4-ohm loads, you'll probably start pushing things out of range for the BOSE amps.
In my experience, the people I've known who have replaced factory Bose drivers with aftermarket drivers (and kept the Bose amps) have been unhappy with the results.
I'd highly recommend using all aftermarket drivers and amps, and removing or disconnection all the Bose equipment. Unfortunately, intermixing things will rarely result in quality sound.
Old Feb 17, 2004 | 08:15 PM
BoostTed's Avatar
BoostTed
speaking from experience with the Audi i see. Yea i gotta agree, the Bose system if the one in the Z is like the other bose system uses an odd Ohm configuration(1ohm or so) and is not compatible with most aftermarket speakers.
Obadabot
Jun 18, 2023 11:31 PM
sales@czp
Sep 23, 2019 03:30 PM
