Nav door stuck after stereo swap
Old Jul 18, 2015 | 08:06 AM
Oz 350z's Avatar
Oz 350z
Default Nav door stuck after stereo swap
I replaced the stock Bose stereo with a reconditioned unit following a DIY with no problems EXCEPT...
In order to remove the center console you have to disconnect the GPS control panel.
When re-assembling the console the Nav door did not open after power was applied, probably because the GPS control panel was not connected. There was no way I could see to reinstall it without opening the door.
Tried connecting the control panel (off to the side) to get the door to open but no luck.
With the control panel connected the GPS system is on and operating normally behind the door.
Does anyone have any suggestions?
Old Jul 18, 2015 | 08:12 AM
Oz 350z's Avatar
Oz 350z
BTW, failing some kind of a reset solution, how would I manually retract the door without damaging the drive?
Old Jul 19, 2015 | 04:12 PM
sportbiketed's Avatar
sportbiketed
The control panel doesn't interfere with the operation of the door. Make sure the plug and ribbon cable for the door are still attached/undamaged.
Old Jul 19, 2015 | 05:55 PM
billydabiller's Avatar
billydabiller
I had a little problem like that too with my door I just kinda moved it a little from side to side and it worked fine
Old Jul 24, 2015 | 01:04 PM
cashmoney03's Avatar
cashmoney03
The door has a button on the front that releases it and then springs retract it up. There's nothing electrical about it other than when it opens it turns the system on. I've had mine off half a dozen times now and have no issues.
Old Jul 25, 2015 | 09:21 AM
sportbiketed
This is true for base models, not NAV models.
Old Jul 27, 2015 | 09:25 AM
cashmoney03
I have a touring with nav. No electronics on mine to open the lid.
Old Jul 27, 2015 | 10:51 AM
sportbiketed
Notice the small motor on the NAV lid? Like I said, base is spring loaded, NAV is electric.
http://www.courtesyparts.com/350z-pa...5_824_834.html
Cash, does your lid close automatically when you push the button?
Old Jul 27, 2015 | 12:50 PM
cashmoney03
Nope. And yes, nav is factory. I'd love for it to be electric. Means it would stay in place better than it does now. I really need to quit being a lazy jackass and adjust the latch on that thing.
Workshop12
Mar 23, 2020 01:45 PM
SharX59
Sep 27, 2015 09:23 AM
416blueZ
Sep 25, 2015 10:00 AM
