Amp Placement
Old Feb 20, 2004 | 06:16 PM
zand02max's Avatar
zand02max
Originally posted by oaktown350
Oh I see! So it is not attached at the back or bottom? Do you worry about the entire rack bouncing?
Thank you guys!
Mine is screwed into the metal, no moving
Old Feb 20, 2004 | 07:05 PM
hndumafia's Avatar
hndumafia
my amp rack is attached to two metal bars (not really bars just pieces of sheet metal sorta). they come down from the roof of the large area and each have a threaded opening for a bolt. so i bent two pieces of sheet metal to attach to there and then curve around and attach to the bottom of my amp rack holding it in place. hardest part of doing this was being able to get the bolts in after putting in the amp rack with the amps mounted because it's tricky to get your arm around the amps and to where you have to tighten the bolt.
Rajiv
Old Feb 21, 2004 | 01:06 AM
oaktown350's Avatar
oaktown350
Looks like this will be a fun project! Thanks for all your input!
Old Mar 8, 2004 | 11:35 PM
oaktown350's Avatar
oaktown350
Just wanna thank you all for the amp install advice. I finally got my system setup over the weekend!
The install is not as pretty as you guys', but it'll do.
I made a mounting platform so I can slide the rack in and out easily for servicing and tuning.
Here it is before sliding the rack in. Notice I mounted the platform to the front and the back just as you guys taught me!
Here it is with it installed
Thanks again guys!
Old Mar 16, 2004 | 07:24 AM
bigern1970's Avatar
bigern1970
Default intall with pictures
Heres my install it clean and kinda of a show peice , I did it all myself jl amps w7 10 inch, rf capacitor, and eclipse deck , tv in stock location, with xbox in glove compartement
m_0g
Jun 3, 2021 10:05 AM
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
Depravity
Oct 1, 2015 04:49 PM
Shane86
Sep 17, 2015 05:33 PM
