only replace stock sub?
Old Feb 22, 2004 | 05:04 PM
discusdave's Avatar
discusdave
Default only replace stock sub?
Hi guys,
I just bought an '04 Chrome Silver Touring Roadster. Great car.
Would it do any good to just replace the stock 10" sub with say, a JL 10 inch unit? Is a direct swap possible? I don't know if I want to do a complete amp/sub swap, but I don't know if it would help the stock system to just do the sub, if it can even be done.
Any help is greatly appreciated.
Thanks!
Dave
Old Feb 22, 2004 | 06:13 PM
Strife350z's Avatar
Strife350z
Dave, AFAIK you have three options:
1) replace the stock sub with a free-air 10 inch: i've heard this personally and although it does sound better, it's not dramatic
2) rip out the stock sub and put a 8 or 10 inch in a custom box in the same location: sounds much better, but probably won't have "punch" to it - do a search on the forum, a lot of people have done this and gone on to different setups
3) rip out the stock sub and put a basslink in there: probably your easiest solution, but suffers the same as option 2)... won't have punch
I started off thinking the same way you did, but after some thorough research, i'll probably end up getting a pair of 10's or 12's in a custom box under the strut bar. Based on what i've seen in this forum, that seems to be the best approach... but then again i like to hear AND feel my bass... so for you, options 1, 2 or 3 might be sufficient.
hope this helps
Rev_Night
Nov 7, 2020 06:00 PM
ablaine
Nov 29, 2016 10:13 AM
