New Android head unit shift knob removal?
Old Jul 13, 2022 | 05:58 PM
MyZ4U2C's Avatar
MyZ4U2C
Default New Android head unit shift **** removal?
Im about to get a new android head unit installed. Do they have to remove the shift **** to do so? I have a 2003 350 and to remove that shift **** you basically have to destroy it.
Old Jul 13, 2022 | 08:02 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Yes, sort of (you can jury rig but not worth it) as the entire waterfall assembly needs to be lowered/removed. Or, just use a rubber strap wrench to remove the shift ****.
Check out Anthony’s vid to get an idea….
https://m.youtube.com/watch?v=mkBRvn1wwzI
Old Jul 14, 2022 | 06:15 AM
MyZ4U2C's Avatar
MyZ4U2C
Thanks for the info! I have a new shift **** my local performance shop is going to install and they let me know there is a good chance the stock **** will be ruined coming off which im okay with. Was thinking I may need to have the shift **** replaced before doing the head unit as I dont think a car stereo place is going to do any better with the **** removal.
Old Jul 14, 2022 | 08:13 AM
travlee's Avatar
travlee
Master
there is enough play in the boot to just move it out of the way
Old Jul 14, 2022 | 09:14 AM
Heel Til I Die's Avatar
Heel Til I Die
Yep - you can leave the **** **** on to do the audio install. As Trav mentioned, the boot has enough flex to twist that plastic assembly out of the way.
When I had to remove the **** to drop my transmission, I used some old rubber garden hose that I cut into sections and then slid those over the jaws of some channel-lok pliers and slowly twisted it off. Or, you can wrap a towel around it and use some pliers to avoid damaging the leather. Just make sure you also have a set of pliers holding the linkage below the **** in place so you don't screw up anything internal in the transmission when twisting.
Heck, I think I have my OEM **** laying around somewhere when I got my over-priced TK Hebi Bebi. Since you're local, hit me up if you destroy yours.
Read your post too fast. I see you already have a new one. What did you go with?
Old Jul 14, 2022 | 10:55 AM
MyZ4U2C's Avatar
MyZ4U2C
Thanks Heel I appreciate it! I didn't want to hold off on this install but now I will go ahead. Been wanting this upgrade for a long time!
m3a5g0
Wanted
Mar 27, 2011 05:57 AM
iconn350Z
Apr 12, 2010 04:24 PM
draoz4
Aug 8, 2008 01:24 PM
MSOsr
Jun 14, 2002 05:53 AM
