Bose troubles
Old Nov 9, 2025 | 12:38 PM
hulkout's Avatar
hulkout
Default Bose troubles
I tried doing searches both on this forum and Google but I came up mostly empty.
my passenger side speakers all are not working and cds skip like mad. Would a new head unit solve this possibly? It seems like this might be a common issue?
Old Nov 10, 2025 | 05:07 AM
Heel Til I Die's Avatar
Heel Til I Die
If it's the OEM Bose head unit, then yes as far as the CD skipping issue. I would imagine that a new head unit would solve that problem. Curious if CD player head units are still a thing...
With regard to the right channel being out, that could be a number of things. For instance, the head unit's right channel output may not be working or there could be a break in the signal somewhere. Lots of possibilities.
If you're keeping the Bose factory speakers and swapping out to an aftermarket head unit, then you'll need a wiring interface like the PAC ROEM-NIS2 since the Bose speakers operate off a low ohm (like 1/2 or 1 or something like that) and the standard head unit has a 4 ohm impedance. I know there are some who have not used this and there are some bootleg workarounds, but this is the tried and true method.
Old Nov 10, 2025 | 08:15 PM
icer5160's Avatar
icer5160
You can still get aftermarket head units with built-in CD players, but most of the market has moved away from such things. If you have an extensive CD library, I highly recommend ripping/copying everything onto a PC in either .wav or .flac format to keep the audio fidelity intact. You can then copy over to a USB stick and play your entire library from there, no more skips or swapping out CDs! Also a good thing to do since CDs are prone to damage. Protect your investment!
Note: Not all modern headunits can natively play .wav and .flac formats (also referred to as High-Res Audio). If you do plan to upgrade, do your homework on this stuff. So far I've been very happy with my Kenwood (DMX908S), I still have my CD Library, but I spend a few days ripping everything to wav and copied my whole library over to a USB thumb drive. Sadly not all my rips came out 100% perfect most of my discs are scratched up and need some restoration.
Decisions to be made! Let us know what your plans are and perhaps we can help advise.
Cheers!
-Icer
cpanagio
Dec 19, 2006 04:14 AM
03track
Nov 8, 2005 10:36 AM
ZlleH
Oct 28, 2005 11:35 PM
silverz
Aug 17, 2002 01:34 AM
