Z Trim Panel & XM Radio Questions
Old Mar 12, 2004 | 11:40 AM
D@ActiveTuning's Avatar
D@ActiveTuning
Default Z Trim Panel & XM Radio Questions
1. I got the Z trim panel used from somebody. Not sure if there's a link for the install, but I couldn't find it (besides the one that was modified). Does the cage for the radio go through the trim panel? If so, I tried that and it doesn't line up right...If not, then what? I also have the Pioneer 850MP like somebody else had on here using the panel too...Looking for advice! Did you have to get something that makes the radio stick out further, because right now if the radio is in the dash, it won't open up..
2. I put XM in through a Pioneer tuner. No sound is coming out (although it's working through other sources), and it's picking up stations because it shows it on the headunit...Any ideas?
Old Mar 13, 2004 | 06:44 PM
D@ActiveTuning
Ok updates on both things:
1. I ended up modifying the trim panel in order to get it working the way I wanted. More to come later on, as it's not quite done yet
2. I fixed XM, it was a stupid mistake on my part. I accidentally plugged it into IP-Bus In, rather than IP-Bus Out lol!
Rowlett
Misc.
Oct 2, 2015 10:38 AM
Tochigi_236
Sep 27, 2015 03:40 PM
