Infinity Kappa 62.5i Crossover Failure
Old Mar 28, 2004 | 04:20 PM
zachcrosen's Avatar
zachcrosen
Default Infinity Kappa 62.5i Crossover Failure
I installed my Infinity's a few weeks ago and amped them this past weekend (week and a half ago). This past friday I noticed a popping in my right rear speaker when I turned the ignition switch off. Today I noticed that that same speaker was no longer working. I turned my ignition switch on and off several times and it began working again. However, the sound was so muffled and staticy that it was unusable. So I removed that speaker and hooked it up in the left rear speaker area and it worked perfectly fine. I then hooked the one that was on the left side up to the right location and it showed the same results. I have determined that something has caused the crossover that came with my Infinity's to go bad. Has anyone else encountered this problem? If so, is there a quick fix or do I need to purchase a new crossover? Unfortunately, I purchased these speakers from an online retailer that is not an authorized dealer. Any help would be greatly appreciated. Thanks.
Old Mar 28, 2004 | 10:51 PM
Beaker02's Avatar
Beaker02
Take a look in the x-over. Not many parts & EZ to fix. Good luck.
Old Mar 29, 2004 | 01:05 AM
oaktown350's Avatar
oaktown350
Try taking apart the crossover like Beaker said. If it is a loose wire then it's easy. If it's a fried electronic, I doubt you have the technical know-how to fix it. You can always purchase a new pair from crutchfield, and then return the broken pair. This is highly unethical though. Just a thought.
Old Mar 30, 2004 | 09:05 PM
hndumafia's Avatar
hndumafia
if you want i have a pair of x-overs for the 62.5i's that i can sell you.
i don't really know how much they are worth but if you want PM me a price. i know you only need 1 but if i sell only 1 i'll never be able to do anything with the other.
Rajiv
JjL
East Canada
Jun 12, 2019 03:04 AM
Stevo Z
Oct 3, 2015 09:14 PM
