what size door speakers fit in stock locations??
what size speakers fit in the factory location??
also can you jsut change the head unti and intergrate the factory speakers with the new unit??
All 4 speakers are 6.5's. However, if you replace the door speakers, it is likely that you will have to have a spacer for the speakers due to the depth of the magnet. Just do a search and you will find out how to make a spacer out of the factory speaker spacer. If you have the Bose system in your Z, then I believe you will have to either have a LOC for the speakers or you could just run all new wiring to each of the 4 speakers, which is what I originally did. This will just depend on what exactly you plan on doing or the amount of work you are willing to put into it. Hope this helps a little.
DarkCreep
Oct 17, 2015 11:50 PM
Subarism
East Canada
Sep 23, 2015 06:09 PM
