Rear Speaker Grilles-
Old Apr 16, 2004 | 11:31 AM
Twistedframe's Avatar
Twistedframe
Question Rear Speaker Grilles-
Is there an easy way to pull off the grilles off of the speakers behind the seats? Or do you have to pull off the entire plastic piece that they are stuck into?
Old Apr 16, 2004 | 12:01 PM
noahbuddy's Avatar
noahbuddy
the grills don't come off... it's all one molded piece of plastic
Old Apr 16, 2004 | 12:58 PM
Twistedframe
Cool. Thanks!
Old Apr 16, 2004 | 07:20 PM
zachcrosen's Avatar
zachcrosen
Actually, the grilles do come off. However, you must first remove that large panel. You then have to cut 2 little things for them to be removed. They then just snap into place.
Old Apr 17, 2004 | 11:48 PM
Twistedframe
Oh sweet!
Have you done this? Do they rattle or vibrate after that?
Old Apr 18, 2004 | 08:52 PM
pearl430's Avatar
pearl430
yes the grill comes off but u can't take off the speakers because it is larger than the grill hole
Old Apr 19, 2004 | 08:46 AM
zachcrosen's Avatar
zachcrosen
On my rear grilles, I took and cut out the factory grille portion of the grille piece. All this left was a trim piece about 1/2" wide. I then bolted the grilles that came with my Infinity's onto this trim piece I made from the factory grilles. I also cut out the holes in the big cover so that i can have easy or fairly easy access to remove these speakers without having to tear the whole rear of the car apart. I then took some double stick padded material and stuck a few pieces to the large cover and replaced the newly fabricated speaker grilles and I have not noticed any rattle or other noise. Some day i will take some pix of my install and post them on here.
3vilbunny
Jul 18, 2017 05:10 PM
