Rec. Sub for Punch Amp? 600W
Old Jun 4, 2004 | 12:57 PM
boma's Avatar
boma
Default Rec. Sub for Punch Amp? 600W
I have a RF Punch 201S amp that I just got from Best Buy for $99.
Specs.
Rockford Fosgate 201S Car Amplifier 600 Watt 2CH Amp
Suggested Retail: $179.00
This amplifier bears the Rockford Fosgate Seal of performance and quality! Included in this unit is 80-120 Hz 12dB variable HP/AP/LP crossover for superior sound and performance, RCA and High Level Inputs to facilitate set up and speaker installation, and 6 - 12 dB Bass control switch. If power is what you are looking for in an amplifier, then the 201S has got what you need. At 100 Watt x 2 (200 Watt x 1), this amp packs enough punch to live up to its name! As part of the Rockford Fosgate Punch series amplifiers, the 201S comes with MEHSA High Performance Thermal Technology designed to squeeze more wattage from every output device while providing consistent thermal stability, NOMAD protective circuitry to help promote the life of your system and reduce circuit malfunctioning, and TOPAZ circuits designed to eliminate engine noise. A real treasure in audio pleasure!
50 W X 2 @ 4 Ohms RMS
100 W X 2 @ 2 Ohms RMS
200 W X 1 @ 4 Ohms Bridged RMS
600 Watts Peak/Max
What is a good sub to match this amp? Thanks !
m_0g
Jun 3, 2021 10:05 AM
sherm
Apr 11, 2020 05:21 PM
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
Shane86
Sep 17, 2015 05:33 PM
